one inch riser motor mounts after suspension lift? - JeepForum.com
post #1 of 5 Old 05-16-2010, 05:58 PM Thread Starter
JOExFROMxNY
My '88 YJ has a 4" RC suspension lift from the prior owner. My motor mounts are shot, and i am looking at replacements. Would i benefit from these lifted ones or should i just use the stock replacements. My transfer case is already hitting (in fact resting on) my lowered skidplate. Do i have to get support under the motor if i only remove one at a time?
CIMG3092 (Medium).JPG   CIMG3099 (Medium).JPG   CIMG3073 (Medium).JPG   CIMG3077 (Medium).JPG
JOExFROMxNY is offline
post #2 of 5 Old 05-16-2010, 06:15 PM
Burnerman
Burnerman's Avatar
Your trans mount has to be shot. Even with my 1" mml and transfer case drop I never had my transfercase hit the skid. Get a new poly trans mount. As far as engine mounts you can maybe squeeze a 1"mml in with stock body mounts but you really need a 1" BL to keep some firewall clearance..
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 5 Old 05-16-2010, 07:53 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Check this thread:
http://www.jeepforum.com/forum/f12/t...plate-1022475/
In short, the clocking on his tcase is not standard.
Joe Dillard is offline
post #4 of 5 Old 05-16-2010, 07:59 PM
Burnerman
Burnerman's Avatar
I thought I saw that pic before! Thanks Joe. I'd get that clocked up and off that skid then. A MML will make it even worse.
96 ZJ.
post #5 of 5 Old 05-16-2010, 08:02 PM
Joe Dillard
If you are thinking that raising the engine will help with the tcase rubbing issue - wrong. You'll make it worse.
Take a second & think about it.
Your engine is set in place by it's motor mounts & the tranny has its mount (yours is dropped).
Since the tcase is past the tranny, the tcase will tend to get lower if you raise the engine up.
Yes, you should support the motor with a floorjack (or something similar) while replacing the motor mounts. I like using a block of wood under the oil pan. And yes, replace one side at a time but loosen all the bolts (do not remove all at once) so there's some wiggle room.
Two inch body lift= 2 Inch motor mount lift? TOLjeep TJ Wrangler Technical Forum 12 10-01-2011 09:36 AM
4 inch Suspension lift and 2 inch coil spacer? Nick716 TJ Wrangler Technical Forum 8 05-30-2011 10:47 AM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 10:12 PM
4.0 Motor mounts Poly vs Rubber, Stock height vs. 1 inch lift Will91YJ YJ Wrangler Technical Forum 16 11-09-2008 08:38 PM
1" riser motor mounts savage yj YJ Wrangler Technical Forum 3 01-11-2006 09:07 AM
