OME spring?'s - JeepForum.com
post #1 of 14 Old 03-14-2012, 08:36 AM Thread Starter
jonny93yj
OME spring?'s
Looking to order my springs, just had a quick ? A lot of folks are saying to go with the 36R all the way around, was just curious why? Is it because these will give you the most lift? the ride quality? I'm going to go with my gut and go with the majorities advice, but thought I'd ask what the advantages are.
jonny93yj is offline
post #2 of 14 Old 03-14-2012, 08:54 AM
copleydad
copleydad's Avatar
Hey Jon. Just replied to ur PM.
A lot of guys run them on all 4 corners, say they are heavier duty. I've got the 036 on the back and the 014 up front and have no complaints. That's what ARB recommended to me before I purchased.
I sent you the number for Iron Pig, but you can also check with ARB tech line, they supply OME in the US. 425 264 1391.
Take care. Bob
'89 Islander 4.2l 5 speed
'14 Grand Cherokee Limited 3.6
One Jeep is Never Enough
copleydad is offline
post #3 of 14 Old 03-14-2012, 09:08 AM
jbolty
jbolty's Avatar
Take care. Bob
I had the same set up but the front sagged pretty quickly so I swapped in a set of 36.
If you have any kind of heavy bumper and especially a winch you need the heavy springs in front.
jbolty is offline
post #4 of 14 Old 03-14-2012, 09:24 AM Thread Starter
jonny93yj
Well as of now I have no heavy bumper or winch. Deffinatley will in the future, but if I go 36 up front without the added weight is it gonna be a super stiff ride untill I get heavy up front?
post #5 of 14 Old 03-14-2012, 09:27 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
I've been told it will ride and flex fine without heavy stuff. Because when I get my springs I probably won't have anything heavy either.
Michaelgoesrawr is offline
post #6 of 14 Old 03-14-2012, 09:45 AM
jbolty
jbolty's Avatar
Will not be a stiff ride. Make sure you put on some nice flexy greaseable shackles at the same time.
I have had my springs on for about 3 1/2 years now and with a pretty heavy rear bumper and tire swing with a 35 on it the back springs have pretty much sagged flat. I put in an add a leaf as a temporary fix and even that did not really make the ride any stiffer or affect the flex. Can't say enough good things about OME springs.
jbolty is offline
post #7 of 14 Old 03-14-2012, 12:10 PM
imstillatwork
I have 36r on front with a light (30lb?) bumper and stiff is the last word you could ever use to begin to describe the ride.
imstillatwork is offline
post #8 of 14 Old 03-15-2012, 11:38 AM Thread Starter
jonny93yj
Take care. Bob
I did try calling ARB and got some old lady. Haha, after that I just decided to go ahead and order the 36R's all the way around. Also got my SYE kit and driveshaft ordered from Tom Woods, and my boomerang shackles ordered from crabtree tool & die. I'm psyched, broke, but psyched.
post #9 of 14 Old 03-15-2012, 12:25 PM
19OlllllllO41
19OlllllllO41's Avatar
You wont regret the 36R's all around, that's my set-up and I couldn't be happier.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #10 of 14 Old 03-15-2012, 02:44 PM
copleydad
copleydad's Avatar
I have felt that way MANY MANY MANY times
post #11 of 14 Old 03-15-2012, 04:40 PM
giggityjeeper
you wil lbe happy, I ran 14 front and 36 rear fgor a few years, then went SOA and did 36 fronts, love them, love them love them...
there will never be another spring under my jeep
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #12 of 14 Old 03-15-2012, 04:56 PM
copleydad
copleydad's Avatar
Well said Gig. 110% Agree.
post #13 of 14 Old 03-16-2012, 06:17 AM Thread Starter
jonny93yj
Another question off-topic from springs. I will be keeping the sway bar, so I'm looking for some quick discos. I was looking at the JKS quicker disconnects. Anyone using these? Is it a huge advantage to be able to remove the whole link, or is it pretty minimal? How much of a PIA is it to put conventional quick discos back together on an uneven ground?
post #14 of 14 Old 03-23-2012, 08:28 PM Thread Starter
jonny93yj
Got my springs, SYE kit and D/S from tom woods today. Just waiting on my shackles. Quick question, the + on the spring goes towards the front, right? Also how do I remove the shim on the springs that will be up front? Do I need to take the nut off the pin and pull it? Or will the shim pop over the pin? I'm using 36R springs in the front?
