OME spring narrow? - JeepForum.com
post #1 of 15 Old 12-26-2012, 05:32 PM Thread Starter
kjg26
kjg26's Avatar
OME spring narrow?
I'm digging into my 36R install and noticed that my daystar bushings and bushing sleeve stick out about 1/8 inch on either side of the spring eyes. I measured the width of the spring eyes compared to the factory springs and they are narrower. The springs are all marked 36R, 2 of them have a 0 at one end and the other two have a - sign. What gives? Is this ok?
Also where can i buy JUST the main eye bushing sleeve?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 15 Old 12-26-2012, 06:50 PM
Mark05059
how wide are the springs?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 15 Old 12-26-2012, 06:56 PM Thread Starter
kjg26
kjg26's Avatar
Factory measure 2.5 inch at the eye. The ome 36R measure 2.25 inch at the eye.
kjg26 is offline
post #4 of 15 Old 12-26-2012, 07:29 PM
Mark05059
sounds like they might be made incorrectly? They should be 2.5" wide
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #5 of 15 Old 12-26-2012, 07:37 PM
gunshw301
My 14fs are 2 5/16 inches as best I could see. I would not worry about it.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #6 of 15 Old 12-26-2012, 07:41 PM Thread Starter
kjg26
kjg26's Avatar
Ill be giving them a call in the morning. Thanks
How bout where to get a single bushing sleeve?
kjg26 is offline
post #7 of 15 Old 12-26-2012, 07:52 PM
gunshw301
http://www.quadratec.com/products/pr...hing&submit=Go
I also had to get new bolts and sleeves as they where beyond usable after I got them out. I think I had to order two or three times to get all the extras after I started tearing into it. Bushings are the same size as stock.
post #8 of 15 Old 12-26-2012, 07:55 PM
gunshw301
Misread, you just need sleeves...I had to buy this kit to get them....
http://www.quadratec.com/products/56005_03.htm
post #9 of 15 Old 12-26-2012, 07:57 PM Thread Starter
kjg26
kjg26's Avatar
I've got greasable bolts/sleeves/bushings that I installed a year ago or so. They are a pain to remove. Don't want to invest in those again and saw no real improvement. Ill prob just get standard bushings/sleeves
kjg26 is offline
post #10 of 15 Old 12-26-2012, 08:03 PM
gunshw301
Just checked to see if I had any leftovers, sorry I don't. I could swear I had some though, if I find them soon I will let you know. I think your springs are fine though.
post #11 of 15 Old 12-26-2012, 08:13 PM Thread Starter
kjg26
kjg26's Avatar
That's b awesome. Thanks.
kjg26 is offline
post #12 of 15 Old 12-26-2012, 10:34 PM
imstillatwork
OME 36R are 2.25"
Use the OME bushings. The set includes two different sizes. The bushings with the thicker shoulder go on the shackle end spring eye. The bushings with the narrower shoulder go on the frame.
imstillatwork is offline
post #13 of 15 Old 12-26-2012, 10:37 PM Thread Starter
kjg26
kjg26's Avatar
I was not intending on using the ome bushings. I know stupid, but i dislike the yellow. Was hoping to use something in black. They are OEM size so any bushing that works wirh factory springs SHOULD work.
kjg26 is offline
post #14 of 15 Old 12-27-2012, 05:54 AM
Rproject
1987 YJ Wrangler
Daystar makes bushings that will work in the OME springs.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #15 of 15 Old 12-27-2012, 05:59 AM
hemishot
I had the same issue when I installed my OME springs. Called them and they said to use their bushings. I am sure some of it is product push, but everything went together without any issue.
hemishot is offline
