Old man Emu leafs bushings? - JeepForum.com
post #1 of 12 Old 06-03-2013, 08:08 PM Thread Starter
aleh17
Hey guys, quick question, I tried to search but I'm confused and need to know the answer quick in order to order the parts I need, otherwise my YJ will not be driveable and I can't afford that since it is my DD.
I want to replace my worn out leafs using OME since I have heard they ride like coils, I'm about to order but I also need to replace my bushings, so I was wondering if I can use any type of bushings like the daystar ones for example or they only work with OME bushing? I ask because OME bushings are way more expensive.
Thanks in advance!
aleh17 is offline
post #2 of 12 Old 06-03-2013, 08:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
A lot of spring eyes are proprietary for this very reason. I would like to know the sizes so what size is it? We can cross reference them all.
Luck Favours The Prepared
Anticanman is offline
post #3 of 12 Old 06-03-2013, 09:38 PM
jbolty
jbolty's Avatar
They are a standard size, I have MORE booms and bushings on mine. Pretty sure they are 1 1/4.
jbolty is offline
post #4 of 12 Old 06-03-2013, 09:41 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Thanks Jeff.
post #5 of 12 Old 06-04-2013, 12:04 AM
imstillatwork
I don't know about others, but OME springs are about 1/8" more narrow than stock, so the 'shoulder' of the bushings are thicker on the spring->shackle and spring->frame bushings If you mix them up things just don't line up right when you assemble the shackles.
imstillatwork is offline
post #6 of 12 Old 06-04-2013, 06:58 AM
Rproject
1987 YJ Wrangler
I went with the OME bushings when I did my lift using the logic that OME made their bushings to specifically work with their springs. The new bushings slipped right in without a big to do. IMHO, keeping things to a brand creates more of a "system".
The OME bushings do not come with sleeves. That's the only thing you'll have to watch out for. I was lucky enough to be able to use my old sleeves as they were in great condition and popped right out of the old bushings.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #7 of 12 Old 06-04-2013, 08:32 AM
kjg26
kjg26's Avatar
I tried using the daystar shackles that I'd recently purchased for the stock springs, they fit, but as said the widths and shoulder widths make them sit funny. I ordered OME bushings.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #8 of 12 Old 06-04-2013, 09:31 AM
jserna
1987 YJ Wrangler
I put some on my bds spings and they fit fine. Only issue i had was the metal sleeve from my shackles were to big. The stock sleeves from the stock springs fit perfectly.
jserna is offline
post #9 of 12 Old 06-06-2013, 01:01 AM Thread Starter
aleh17
Great, that is what I needed to know, thanks guys.
The only doubt I got left is about the sleeves, so I can re-use the stock ones right?
aleh17 is offline
post #10 of 12 Old 06-06-2013, 01:04 AM
kjg26
kjg26's Avatar
I used my factory sleeves.
kjg26 is offline
post #11 of 12 Old 06-06-2013, 02:37 AM
Sparrows
x2
I reused my sleeves with no problems
Cheers
June '13 YJOTM
Sparrows is offline
post #12 of 12 Old 06-06-2013, 07:19 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'm pretty sure the directions say to reuse the old steel bushings. I assisted with a couple OME lifts and its been the rule of thumb both times.
