Old Man Emu 2.5 - JeepForum.com
post #1 of 9 Old 08-26-2011, 09:08 PM Thread Starter
sbs1794
Old Man Emu 2.5
I am going to get old man emu springs (was wondering what problems arise running front springs all around as they are cheaper) and wanted to know what else I needed to get. Where can I get cheap replacement poly bushings that will fit the OME springs, I dont really feel like paying 100 dollars for OME bushings. Can I run the 2.5 lift springs with stock length shocks for a little until i get new shocks or no? Thanks.
sbs1794 is offline
post #2 of 9 Old 08-26-2011, 09:46 PM
jbolty
jbolty's Avatar
The reason to get OME is the flex and ride quality. If you want to get the most out of the springs don't cheap out.
Get the heavy duty springs for all 4 corners.
Chances are the stock shocks will be too short.
Get the proper bushings with greaseable bolts.
The MORE shackle, bolt and bushing kit is not all that expensive.
jbolty is offline
post #3 of 9 Old 08-26-2011, 10:55 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
^ What he said, And there are several threads on here about OME there are even a few build threads with ome springs Here is the link to one of the threads using the parts that jbolty has listed .
http://www.jeepforum.com/forum/f22/y...ation-1229681/
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 9 Old 08-27-2011, 07:36 AM Thread Starter
sbs1794
when u say get the heavy duty springs for all four corners do you mean the front heavy duty all around, or the front two heavy with the two rear as mediums
sbs1794 is offline
post #5 of 9 Old 08-27-2011, 07:52 AM
redrubi03
36r leafs front and rear
redrubi03 is offline
post #6 of 9 Old 08-27-2011, 08:02 AM
jbolty
jbolty's Avatar
36R for all four.
originally I had those in the rear and the 14F in the front as recommended but the front sat a lot lower and they sagged almost right away; I did not even have a winch on back then. OME sent me an extra leaf for the front which made all 4 springs the same, big improvement
read this thread.
http://www.jeepforum.com/forum/f12/h...prings-961357/
jbolty is offline
post #7 of 9 Old 08-27-2011, 09:05 AM
hrt4me
I'll be following this same advice and ordering four 36Rs for my '91 YJ
hrt4me is offline
post #8 of 9 Old 08-27-2011, 03:09 PM
19OlllllllO41
19OlllllllO41's Avatar
Exactly what jbolty said!
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #9 of 9 Old 08-27-2011, 04:05 PM
TheNewbie
As usual...
But yes, I plan to move to the same setup when I can.
1995 YJ 2.5 - 4” RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
2.5 , lift , old man emu , ome , springs
