old leafs - Page 2 - JeepForum.com
post #16 of 31 Old 08-31-2014, 02:18 PM
Jeepsr4me
Originally Posted by mike134 View Post
I still have trac bars...
Me too.... I got like 40 of them.. I figure if jeep used 2 of them that more is better...
Mine are in the scrap pile were they belong.
Jeepsr4me is online now
post #17 of 31 Old 08-31-2014, 04:42 PM
amp713
Originally Posted by jeepsr4me View Post
me too.... I got like 40 of them.. I figure if jeep used 2 of them that more is better...
bahahahahaha
I like my YJ how I like my whiskey, on the rocks with just a touch of color!
amp713 is offline
post #18 of 31 Old 08-31-2014, 11:02 PM
BuffaWrangler
Look into OME 2.5" or BDS springs. Same price as OEM, and much better ride. If getting into the Jeep is an issue, get a cheap set of side bar steps for $100. Ride will be a ton better.
My OME 2.5" lift parts list with before/ after pics: http://www.jeepforum.com/forum/f12/about-order-ome-lift-kit-1489830/
BuffaWrangler is offline
post #19 of 31 Old 08-31-2014, 11:30 PM
Mambo_Dave
Just wondering how much a spring shop should charge to re-arch YJ springs?
South Florida is not the type of area one can go and get an honest answer about what a price should be, so I want to find out before calling up a spring shop.
Mambo_Dave is offline
post #20 of 31 Old 09-01-2014, 07:17 AM
Mike Romain
I went to a shop that deals with dump trucks and semi tractors. Their tools are steel, not solid platinum like a 4x4 speciality shop uses and wants us to pay for...
I needed all new bushings and shackles and wanted a 2.5" lift. They got a 2.5" "keeper" spring to replace my first free top one and arched the rest to match with new U bolts. Ran me about $125.00 a set of 2 if I remember right.
Mike
Mike Romain is offline
post #21 of 31 Old 09-01-2014, 05:18 PM
langwilliams
that sounds like a good way to go Mike. I picked up a set of "2-2.5" springs from a guy parting out a jeep with a bad frame. I did the rears this morning an got about 1.5" of lift over the well worn an nearly flat stockers (I think they were stockers). I don't really want to climb into a 5" lifted jeep but I'd like to fit 31's under it. I had 2 shackle bolts come out without a cut off wheel, everything else had to be cut.
langwilliams is offline
post #22 of 31 Old 09-01-2014, 06:48 PM
IA93Javert
I have done a lot of research recently along the same issue and looked at replacing the springs. From what I have read you are going to get a stiffer ride replacing the springs until they are broken in. I ordered the Skyjacker H7055 Softride Hydro Shock Absorbers for 0 in lift after a lot of reading along with my front brake replacement parts.
IA93Javert is offline
post #23 of 31 Old 09-05-2014, 07:06 PM
L_Kilkenny
Check this link:
http://www.fourwheeler.com/how-to/15...pas-and-fixes/
Bottom of it check out "win some, lose some". I'm currently lining up a set of used YJ springs to do this. That and the 1.25" lift shackles that the PO put on will allow me to run my 31's till I put on a small lift with new springs next year. (Fender trimming may also be in order)
'89 YJ (MC Carb, Nuttered, 2.5" OME lift) & '98 4.0L ZJ (2" BB,KOR Rad. Support, 31" BFG 's)
L_Kilkenny is offline
post #24 of 31 Old 09-06-2014, 07:44 AM
Mambo_Dave
Originally Posted by L_Kilkenny View Post
Check this link:
That's pretty cool.
I'm wondering if it's only YJ springs that could work since one is cutting off the ends anyhow. I'd guess that as long as the width was the same, other leafs could work?
post #25 of 31 Old 09-06-2014, 08:07 AM
L_Kilkenny
With the yj springs you are basically trying to "restore" your ride and height. Other springs will work but you'll more than likely gain lift and possibly alter your ride quality. All depends on what you are after. I wondered about using the main from rear XJ springs but they are usually worse and flatter than the POS's that are on YJs. Good luck.
post #26 of 31 Old 09-08-2014, 08:34 AM
medic-11
What you guys are talking about, the "win some lose some" is a bastard pack. It is common to add a leaf from another vehicles spring pack to restore or add lift. The are a few threads on this forum about it, as elk as in other forums.
medic-11 is offline
post #27 of 31 Old 09-08-2014, 11:58 AM
adiubald
you can also search- "add a leaf kits". Along the same lines as a bastard pack without searching for a donor pack. Typically the kits come with a new leaf to be added to your existing pack, new center bolts and clamps. The amount of lift depends on the condition of your current springs.
I added a heavy bumper and winch to my YJ (about 250 lbs). It caused the front springs to flatten and nose dive. The add a leaf kit brought me to +1" now in the front. Now, only I know that the front seems to be a little higher than the rear.
If you do a bastard pack or add a leaf, some amount of fine tuning will be required to get all four corners at the same height. IMO- its worth saving the $$, even if you have to try a couple of times to get it right.
adiubald is offline
post #28 of 31 Old 09-08-2014, 03:37 PM
petertom13
Is it recommended to remove the trac bars or what?
petertom13 is offline
post #29 of 31 Old 09-08-2014, 03:48 PM
Gealii
Remove the trac bars for better flex and ride qualiy. Look up your state inspection to see if you need to save them or just cut me off
Gealii is offline
post #30 of 31 Old 09-08-2014, 03:51 PM
petertom13
yeah, I just read that in the article that someone shared, that was great, saved me from asking a bunch of future questions about my YJ that were bugging me. Including the cracked doors by the vents.
