Old Gas In Tank - JeepForum.com
post #1 of 10 Old 02-16-2013, 12:47 PM Thread Starter
Kim72
Old Gas In Tank
My son's 92 YJ has been in storage for about 5 years while he went to school and got established in a job. We're making plans to put it back on the road. The gas tank is about 1/2 full. I would believe that the gas is pretty stale by now. I tried to siphon it out but can't get a hose into the tank. Would adding new gas to the old be ok at this point?? Any gas additive I can use?? I don't want to have to drop the tank!!
Kim72 is offline
post #2 of 10 Old 02-16-2013, 01:03 PM
pasinbuy
No, drain the tank. I would drop the tank and clean it myself. Dropping the tank is easy. The spray the inside of the tank with carb cleaner to make sure it is perfectly clean.
Bad gas is bad gas. You could burn a hole in a piston by mixing bad gas and new gas. Your risk. Five years is way too long to risk.
Plus by dropping the tank you can remove the 15 gallon tube and make the tank a 20 gallon tank.
Two birds with one stone.
pasinbuy is offline
post #3 of 10 Old 02-16-2013, 01:26 PM
seattle_yj
They make a 1/2 " siphon, it will fit in the YJ and it is manual activation using a ball bearing on the end. They also make a 99$ fluid siphon that is electrical, (i know what you're thinking, danger right?)it is quite common process in the marine industry though.
seattle_yj is offline
post #4 of 10 Old 02-16-2013, 01:34 PM
pasinbuy
Problem with our Yj is that you have to go through two 90 degree turns before being able to siphon fuel.
On from the fuel fill to the tank and the other from the tank opening down to the fuel if I remember right? The hose must be very bendy or flexible.
I still say drop the tank so that you can clean the old varnished gas on the sides and bottom of the tank with the carb cleaner.
pasinbuy is offline
post #5 of 10 Old 02-16-2013, 05:23 PM
clarkmcmp
My son and I pulled a wrangler out of a back yard couple years ago. It was a mess. I threw a battery in it and it started. I tried to just add fresh gas and run with it. I started bending push rods when valves stuck. Ended up pulling the head and taking it to machine shop. The old motorhead told me I was running some bad gas. I dropped the tank and scraped varnish out for couple hours. Put rocks and carb cleaner in the loosen things up. Finally got it all clean. All is good now but skipping the cleaning the tank was not a time saver. Go ahead and convert your tank to a 20 gallon conversion (10 minutes) while you have it out.
clarkmcmp is offline
post #6 of 10 Old 02-16-2013, 08:21 PM
seattle_yj
Does the 20 gal hang down any more than the 16 gal?
post #7 of 10 Old 02-17-2013, 09:47 AM
Louie4
I'd be inclined to pull the fuel line by the filter and let it pump out first then pull the tank as it will be easier to handle.
Of course you need to make sure there are not any open flames, sparks, etc. when doing this and attach a longer piece of hose to have it drain into another container.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #8 of 10 Old 02-17-2013, 10:32 AM
Mark05059
same exact tank. You remove part of the vent inside the filler tube.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #9 of 10 Old 02-17-2013, 01:48 PM
bigbossd1030
You don't actually use a different tank. You use the stock tank. Inside there is a vent tube. This tube protrudes into the tank a certain amount, when you fill the tank the gas splashes up into this tube, triggering the gas pump to stop pumping, telling you it's full. But it's only filled to 15 gallons. By removing this tube, you add an additional 5 gallons to the stock tank. This was an option avail at purchase for an extra cost when really the dealer is actually saving money on the tube.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #10 of 10 Old 02-17-2013, 02:26 PM
seattle_yj
Interesting, thanks for the info.
