Ok, should there be a hole there? - JeepForum.com
post #1 of 6 Old 07-17-2010, 09:44 PM Thread Starter
JJorda
Jeep. Jeep? Jeep! Jeep.
JJorda's Avatar
I was checking the oil on my Jeep ('89 YJ with a 4.2) and noticed a rather ugly hole in the top of the framerail right behind the driver's side motor mount. There's other factory holes in the frame, I was wondering if there was supposed to be a hole there that just got a little rough, or did something rot through? Anyone have a good picture of a solid YJ 6-cylinder framerail?
1989 Jeep Wrangler - Daily Driver and project - Red Jeep Club #216, NRA Jeep Club #5
1967 Chevelle SS396 - Main Project <--454, TH400, 4.10's, FAST
1982 Caprice Classic - Another project <-- 350/700R4, 4 wheel discs
1979 Honda Civic CVCC - Yet another project <--goal of 60 mpg
JJorda is offline
post #2 of 6 Old 07-17-2010, 09:52 PM
MJMPC
Can you post a pic?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 6 Old 07-18-2010, 07:32 AM Thread Starter
JJorda
JJorda's Avatar
Yeah, I'll take one and post it today.
JJorda is offline
post #4 of 6 Old 07-29-2010, 04:14 PM Thread Starter
JJorda
JJorda's Avatar
Sorry I didn' get a picture more quickly - work kept me kinda late over the past few days. This is the best picture I can get, any other angle there's stuff in the way of the camera. This is looking from the front of the engine rearward, the hole is pretty much in the center of the picture. Looks like it may have started where the brake line holder attaches to the frame. Looks pretty bad to me....
JJorda is offline
post #5 of 6 Old 07-29-2010, 04:21 PM
Louie4
That looks really bad to me. If you decide to repair it (hopefully you will) you'll have to pull the motor and cut the bad section out and put some steel plate back over it. I would check the rest of the frame especially the rear upper shackle mounts.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 6 Old 07-29-2010, 04:48 PM Thread Starter
JJorda
JJorda's Avatar
One rear shackle mount has already been repaired, the other one is only just starting to be a little lumpy under the paint. The rest of the body is rust-free, just the frame is a little less than perfect. This winter or spring I'm pulling most of it apart anyway, if I can ge a welder by then I'll fix it then.
JJorda is offline
Can anyone tell me what this hole is? greensaharatj TJ Wrangler Technical Forum 22 03-17-2010 11:33 AM
pcv and other hole?? jcbarton YJ Wrangler Technical Forum 10 04-29-2009 09:01 AM
Hole and Thread size of D44 Axle Vent hole JeepRocks86 TJ Wrangler Technical Forum 1 12-31-2006 04:07 PM
Something Ate a Hole in My Top bigbarr TJ Wrangler Technical Forum 11 09-21-2006 08:55 PM
What is it?? HOLE? wcurleyq TJ Wrangler Technical Forum 6 08-14-2006 09:18 PM
