ok i fixed the shudder - JeepForum.com
post #1 of 4 Old 10-27-2001, 07:09 PM Thread Starter
evilpsych
evilpsych's Avatar
Ok guys.. i fixed the shudder, was a bad mount and perhaps a bit of it is from a u-joint, those are getting replaced in about 10k when i do the clutch.. anyway.. also changed the gear oil in the AX-15.. was a ***** to change it. 15/16" drain plugs? geezus.. oh.. anyone know what size the drain/refill plugs on the NP231 xfer case are? they're really damn big.. i think they're 1 3/16".. maybe metric.. would help out a lot becuase autozone didnt have a clue and i tried all the sockets they had that were in the size range..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 4 Old 10-28-2001, 01:53 AM
Ruftags
1 3/16 is the size I used when I changed mine less than a month ago. They also have a couple of small pumping devises that will attach right to the bottle you are pumping from. This made it alot easier for me.
95 YJ 2.5L AX5 30in. rubber.
So many upgrades/So little cash!!
Ruftags is offline
post #3 of 4 Old 10-29-2001, 11:19 AM
Kev
Master of the Obvious
Kev's Avatar
I've always used 30mm sockets on the transfer case, same as Chevy/GMC transfer cases...
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #4 of 4 Old 10-29-2001, 01:34 PM
OhYeah
Yep, after a lot of BS trying to find out the answer to that same question. It is a 30mm socket.
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
what causes this shudder? JeSimmers TJ Wrangler Technical Forum 13 02-27-2008 09:41 AM
shudder bigd23 JK Wrangler Technical Forum 10 08-01-2007 06:55 AM
shudder shudder TG32 TJ Wrangler Technical Forum 5 03-15-2007 02:36 PM
Shudder?? The Fuzz YJ Wrangler Technical Forum 10 09-23-2005 12:31 PM
shudder ?? J33p3R17 TJ Wrangler Technical Forum 3 12-01-2004 04:03 PM
