ok guys.. the shuddering is gettin bad.. - JeepForum.com
post #1 of 3 Old 10-26-2001, 08:25 PM Thread Starter
evilpsych
evilpsych's Avatar
ok.. shuddering/vibration is gettin bad. i'm going to take the skid plate off to check the tranny/transfercase mount for play.. then the fluid levels.. do i need to jack up the tranny before i pull the skid plate off? i htink i do, but i'm a moron..
hopefully it's a U-joint or the mount, i really dont want to rebuild the tranny for awhile.. bought mobil one 75w90 gear oil for a drain and refill..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 3 Old 10-26-2001, 09:30 PM
powjunkie
Definately need to put a jack under the tranny/transfer case before removing the skid plate. I would hold off on that, though. Have you checked your rear pinion nut? I know that with a drive line change (from a lift) that the pinion nut tends to loosen over time. This is the nut that holds your rear driveshaft yoke in place at the differential. You have to remove the rear d-shaft to check it. If it's tight, try to move it to see if there's play (up/down, side-side). If so, you may have a bearing or gear problem.
94 YJ 4", SYE, 33 mud t's on MT classics; 4.10's with Detroit Truetrac in rear
powjunkie is offline
post #3 of 3 Old 10-27-2001, 01:37 AM Thread Starter
evilpsych
evilpsych's Avatar
it's a stock vehicle with 110k on it..
A
shuddering AX-15 tranny evilpsych YJ Wrangler Technical Forum 8 07-14-2011 03:07 PM
tranny shuddering?? Beltfed09 JK Wrangler Technical Forum 9 08-28-2009 10:46 PM
Bogging/Shuddering in 4th, 5th, 6th any RPM Jordon83 JK Wrangler Technical Forum 4 07-07-2009 09:40 AM
Need some help (shuddering) BlackJeepin TJ Wrangler Technical Forum 11 06-03-2008 05:39 PM
crazy shuddering ? JaredBoys JK Wrangler Technical Forum 13 03-30-2008 07:22 PM
