Oil Temperature Gauge - JeepForum.com
post #1 of 5 Old 10-10-2003, 10:54 AM Thread Starter
smok3y
smok3y's Avatar
Hey guys my oil temp gauge hasnt worked sinse i got my clutch/slave cylinder replaced. I was wondering if it just came unplugged someone wanna hint me where the plug is located on the block so i can check it out? also, i read a post saying that if your O2 sensor is off it could effect the gauge as well. someone let me know TIA
-Zack
1990 YJ/ 31x10.50 Maxxis Mudders/Removed Sway bar,Rear trac bar/tow hooks. 2" straight pipes from manifold back
White Jeep Club #73,999,999
smok3y is offline
post #2 of 5 Old 10-10-2003, 11:07 AM
LoOpY
the O2 thing doesnt make a lick of sense. engine size would be helpful in this case, but the 4cyl has the oil PRESSURE sending unit by the distributor and the engine COOLANT TEMP sending unit on the T-stat housing (92+)..not 100% certain which youre asking for, but I assume the pressure sending unit
LoOpY is offline
post #3 of 5 Old 10-10-2003, 11:15 AM Thread Starter
smok3y
smok3y's Avatar
Not oil pressure, but Oil TEMP i have a 90 I6 4.2 carb'd is the temp gauge on the oil pressure sending switch?
smok3y is offline
post #4 of 5 Old 10-10-2003, 05:55 PM
LoOpY
are you sure its not aftermarket? i cant find anything on google about an OEM oil temp sensor or gauge...
my guess is that the sensor would either be in the oil pan, or by the oil filter/pressure sending unit.
anyone else have any input?
LoOpY is offline
post #5 of 5 Old 10-10-2003, 06:10 PM
Hackle
Hackle's Avatar
Oil Temp would be after market so who know where it is located.
89 YJ Nearly Stock:)
3 link w/ coilovers front. 4 link coil over rear, 39.5" IROC's, Walker Evans Beadlocks, Rear 60 w/spool, Tera Low, Front 60 w/ OX Locker, Warn 9000, & a few others. New 4.0 HO
Hackle is offline
Temperature gauge Jblood YJ Wrangler Technical Forum 16 08-23-2012 02:22 PM
My temperature gauge is at zero ? somar YJ Wrangler Technical Forum 0 11-17-2008 10:51 AM
Temperature Gauge mxracer513 YJ Wrangler Technical Forum 13 05-15-2008 12:26 AM
Temperature Gauge rammer YJ Wrangler Technical Forum 4 04-29-2004 09:47 AM
temperature gauge nomad20012 YJ Wrangler Technical Forum 3 10-31-2001 11:32 PM
