oil temp running high - JeepForum.com
post #1 of 6 Old 06-30-2013, 03:59 PM Thread Starter
cdeck
I recently noticed my oil temp jumped one day from 40 to almost 80!! I took it and had a complete 18 point change done on it but now it's running at 70, unless I push in the clutch then it drops down below 40... Do I need to replace pump?
cdeck is offline
post #2 of 6 Old 06-30-2013, 04:11 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
If you're reading the stock gauge, that's pressure not temp. A good rule of thumb is 10 psi per 1000 RPM. So as long as you're not going under that I'd think everything is okay even though I have no idea why your readings are jumping
Oil pressure will be high until it heats up then it will drop as the oil gets thinner.
Oil pressure will be up while driving and drop when idling in accordance with engine rpms. I feel the same goes when you press the clutch in so that would explain why it drops.
Michaelgoesrawr is offline
post #3 of 6 Old 06-30-2013, 04:27 PM Thread Starter
cdeck
TY for the fast response!! I meant pressure gauge lol.. it never jumped like that before, as I said it always ran at 40 and now it runs at 70, I just don't want to blow up the engine,, this is my first Jeep and I'm doing all the mechanical work on it myself.
cdeck is offline
post #4 of 6 Old 06-30-2013, 04:34 PM
Michaelgoesrawr
You may have a blocked oil passage. But I'm not sure. Someone who knows more will be by. Just give it some time.
post #5 of 6 Old 06-30-2013, 05:12 PM
pasinbuy
WTH are we going to even shorten "thank you" with a TY now!
I must be totally out of it these days.
pasinbuy is offline
post #6 of 6 Old 07-01-2013, 07:32 AM Thread Starter
cdeck
Thank You passinbuy for your help on that matter but if you are going to criticize anyone on spelling check yourself first.. ie:WTH.....
cdeck is offline
