oil and temp gauge - JeepForum.com
post #1 of 3 Old 09-01-2010, 05:09 PM Thread Starter
Eugenejeepjeep
oil and temp gauge
I have a 89 yj and my oil pressure gauge goes to the max when i turn the key on
and will move a little, but when i start it it stay at max. With my temp gauge it doesn't move at all when on or running. was hoping some one could tell me how to fix this.. already replaced the temp sensor
Eugenejeepjeep is offline
post #2 of 3 Old 09-01-2010, 05:45 PM
ImpactFabWorks
The oil gauge most likely needs a new sending unit. the Temp gauge could be as simple as the conector coming off the sending unit. The sending unit is towards the back of the head on the drivers side by the fire wall
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #3 of 3 Old 09-01-2010, 06:08 PM
monkeyhouse
you can also pull off the cluster and clean up the contacts. Although I did that and while it did give me lights again, it did little for my gauges.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
help needed , oil gauge , temp gauge
Does the temp gauge sometimes go bad? wildbadbill YJ Wrangler Technical Forum 8 04-13-2009 08:51 PM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 09:01 PM
temp gauge 1992JeepYJ YJ Wrangler Technical Forum 5 10-30-2006 06:12 PM
temp gauge brad2bw YJ Wrangler Technical Forum 4 08-31-2004 09:27 AM
temp gauge ??? Durbahn YJ Wrangler Technical Forum 7 01-07-2004 10:32 AM
