oil pressure sensor - JeepForum.com
post #1 of 5 Old 02-16-2002, 09:40 AM Thread Starter
diverguy
oil pressure sensor
After reading previous posts, I think I need a new oil pressure sensor. The manual does not tell where to find it. Where is it?????
93 yj 4 cly
diverguy is offline
post #2 of 5 Old 02-16-2002, 09:56 AM
Mike611
Mike611's Avatar
u have the 2.5 or the 4.0??? In the 2.5, it is between the distributor and the alternator. It looks like a little 4 inch long cylinder sticking out of the side of the block. Hope that helps, it's a common part that you could find at your local Autozone,,
Mike
95 2.5L, bumpers and hilift, soon to be locked and lifted!!!
95, 2.5L, custom bumpers, Flow's, 4 inch Skyjacker Super Duty, 33x12.50 MT's, 15X10 AR 767's, Hi-lift, Funk in the Trunk( two 12 inch subs ), soon to be locked and have one of those pully things on the front.
If you are going to be a bear, be a grizzly...
Mike611 is offline
post #3 of 5 Old 02-16-2002, 09:56 AM
iamthemellowman
i could be wrong, but on my 6 cyl it's on the oil filter attachment flange. i believe it's one wire too.
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
post #4 of 5 Old 02-16-2002, 05:26 PM
Atropine
Atropine's Avatar
it is on the right side, it plugs right into the block right near the altinator. Its attached by 1 brown wire.
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #5 of 5 Old 02-16-2002, 06:16 PM
evilpsych
evilpsych's Avatar
thanks. found it. was pretty obvious, (right by the oil filter actually)
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
05 TJ Oil Pressure Sensor LeBeteNoire TJ Wrangler Technical Forum 6 10-28-2009 12:34 PM
Oil pressure sensor leak? NPjeep YJ Wrangler Technical Forum 3 10-27-2009 05:26 PM
Oil Pressure Sensor - Plug localbulldog TJ Wrangler Technical Forum 7 02-16-2009 05:57 PM
Oil Pressure Sensor wrangler2002 TJ Wrangler Technical Forum 5 06-14-2004 02:15 PM
oil pressure sensor jt_Jeep YJ Wrangler Technical Forum 3 06-13-2003 02:05 AM
