Oil pressure sending unit confusion - JeepForum.com
post #1 of 7 Old 01-20-2014, 11:41 AM Thread Starter
Kudu
These parts are both listed as the sending unit, but look different. Which one is it, couldn't find proper info searching forum. You tube videos show each version being used.
http://www.quadratec.com/products/917219_07.htm
http://www.quadratec.com/products/55108_07.htm
I think I want the plug and play one.
Kudu is offline
post #2 of 7 Old 01-20-2014, 11:51 AM
TEXAIR
It depends on the type you have now. Look at the plug for yours. I am willing to bet the first link you show is the correct one.
89 YJ, 4.6 Stroker, SOA, Waggy 44 and Ford 8.8 w/ARB's. Rollin 35" BFG's. Raptor Lined Body.
TEXAIR is offline
post #3 of 7 Old 01-20-2014, 12:41 PM
Berniebikes
Nope, one's a sending unit, one's a switch. The sending unit to your gauge takes a single purple (color may be diff) wire. The switch, which controls your manifold heater (connected to the relay and won't allow the manifold heater to come on until there is oil pressure) takes two wires. Not sure of color. The first item you list is the switch. The second item is your oil sending unit.
Berniebikes is offline
post #4 of 7 Old 01-20-2014, 12:51 PM
Mark05059
he doesn't have a manifold heater since he is injected.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 7 Old 01-20-2014, 02:07 PM
Mambo_Dave
Pep Boys has the larger one - the sending unit - for less than that.
Like under $18 IIRC.
Mambo_Dave is offline
post #6 of 7 Old 01-20-2014, 05:21 PM
kloppk
For your 1995 4.0 you need the first one you have listed.
The OEM part number for your oil pressure sensor is 56026779
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #7 of 7 Old 01-20-2014, 08:39 PM Thread Starter
Kudu
Yes I took a look that is clearly the part. Thanks.
Kudu is offline
