Oil Pressure sending unit - JeepForum.com
post #1 of 8 Old 09-04-2008, 03:48 PM Thread Starter
boaty1
boaty1's Avatar
I replaced my oil sending unit a few months ago and now I think it might be going out again.* Is this normal that they can go out so fast.* Connection seems to be ok.* It jumps around and pegs alot.* Is this the problem???* Thanks guys.
And I thought my other hobbies were expensive!
90 yj, new reman 4.2 ax15, weber 32/36, 2 1/2" RC lift, discos, 1" boom shackles, tcase drop (I HAD TOO). homemade flares.
boaty1 is offline
post #2 of 8 Old 09-04-2008, 03:57 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
A short to ground somewhere in the wire from the sending unit can cause this. Check the wire for someplace that may be shorting out on the frame or engine.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 8 Old 09-06-2008, 08:46 AM
88TNSahara
I agree. CHeck for a short somewhere.
On a related note, do you have to drain the oil to change the sending unit? If you change it out with oil in the motor will oil run out all over the place? Thanks!
88TNSahara is offline
post #4 of 8 Old 09-06-2008, 09:02 AM
Exparrot
Exparrot's Avatar
Mine just screwed in with oil in the engine. As long as the engine's not running, there's no pressure and it won't push oil out. Put on a little thread tape to make it seal tight and you're fine.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #5 of 8 Old 09-06-2008, 05:09 PM
J33P'r
She has her top off!!!
Troubleshoot Oil pressure sending unit
I have AMC360, I've located my oil pressure sending unit (Im pretty sure thats it) one post terminal, how can I test it to see if its sending info to the guage? my guage does NOT work at all, so i dontknow if its the sending unit or the guage... and I want to troubleshoot it
J33p'r
"Right tools for the Right Job produce Right Results"
J33P'r is offline
post #6 of 8 Old 09-08-2008, 12:52 AM
Bubba Ray
Try a mech. test gauge kit from someplace like Harbor Freight. Got mine for about 20 bucks.
Bubba Ray is offline
post #7 of 8 Old 09-08-2008, 03:21 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Most all single wire senders (whether oil, temp, fuel, etc.) have 12V applied to the gauge, and the ground is provided through the sensor's single wire. When a complete ground (meaning good ground with no resistance value) is applied to the single wire from the sensor, the guage "pegs" out with it's highest reading. So, if you supply the sensor wire with a solid ground and your gauge reads it's highest reading, you can be reasonably sure that the gauge is working, and that the wiring is okay.
Mean Max is offline
post #8 of 8 Old 09-08-2008, 05:15 PM
dbikers
i put a sunpro mechanical gage in mine for $15 (put it where the clock goes as neither worked)...easy install, looks almost factory and it works like you'd expect it to..very responsive
STUPID HURTS.......OUCH!@#$
dbikers is offline
Oil pressure sending unit lipsandjj YJ Wrangler Technical Forum 8 11-09-2010 08:16 AM
Oil Pressure Sending Unit Joe1167 YJ Wrangler Technical Forum 4 03-20-2009 06:33 PM
Help with oil pressure sending unit jw98tj TJ Wrangler Technical Forum 1 08-29-2004 08:24 PM
Oil Pressure Sending Unit BeatAChevy289 YJ Wrangler Technical Forum 6 07-28-2004 08:22 AM
Oil Pressure Sending Unit OwnAccord TJ Wrangler Technical Forum 3 03-13-2003 07:54 PM
