OIl Pressure Reading - JeepForum.com
post #1 of 6 Old 04-12-2010, 08:16 AM Thread Starter
apaol002
I have a 90 YJ with a 4 banger in it and I am wondering if anyone can point me in the right direction. What is the gauge suppose to read normally for oil pressure? Any help would be appreciated.
apaol002 is offline
post #2 of 6 Old 04-12-2010, 08:38 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
It varies by rig. What does yours say???
The general rule of thumb is 10 PSI for every 1000RPM's. So you can have a rig idle as low as 10 PSI and be upwards of 70PSI at speed. Generally, between 20 and 60 is the norm.
Again, what does yours say???
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 6 Old 04-12-2010, 10:19 AM
RebuildRookie
Rusty is right.
Just for the record mine runs about 65 (consistantly) after an oil change, and it lets me know when it needs another. It will drop to 40 while driving and a little lower (20 or so) at idle.
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #4 of 6 Old 04-12-2010, 05:39 PM Thread Starter
apaol002
Thanks everyone for the input first off. My oil pressure gauge reads anywhere between 40 and 60 when idling. When I give it gas and get some speed it reaches somewhere around 80 - 85. I am just wondering if this is normal or not. I hate seeing the needle go back and forth so much, it makes me nervous. I just want to know if this is normal or should I start looking for a problem, and if so, where do I look?
Thakns again.
apaol002 is offline
post #5 of 6 Old 04-12-2010, 06:14 PM
rustywrangler
The needle will ALWAYS move.
What weight oil are you running and where is the oil level on the dip stick when cold??? That pressure is ok, not great but ok.
post #6 of 6 Old 04-12-2010, 06:48 PM
Wheelman286
It will stay at 50-60 all the time if you put Lucas oil stabilizer in it. That's what mine does. Otherwise, 40 at idle, 50-60 when you're going down the road at speed... usually... as others have said the gauge accuracy is questionable. 80... you might want to check on that.
I bought an 87 MasterCraft Prostar 190 (ski boat) with a 351 Windsor in July '09 and my oil pressure would go to 80 and sometimes max out the gauge (almost 100). There was gas in the oil, so we (me and the old man) took the top of the motor apart and the main gasket was bad and there were a few loose bolts too. Amazingly it ran just fine but how long it would have continued to run in that state is a question I'm glad I never found an answer to.
That boat has VDO gauges though which are incredibly accurate unlike the gauges in YJs. So It could be the gauge but it might not be. Check to see if there's gas or god forbid... water... in your oil. That's how we found out with the boat.
92 Wrangler 4.0 5-speed -Canyon Blue Metallic/Black Interior '00 S2000 Silverstone Metallic/Red Interior '93 S-10 Blazer Tahoe LT Black/Grey Leather Interior
Wheelman286 is offline
Fluctuating Oil Pressure Reading Sammer YJ Wrangler Technical Forum 4 03-14-2007 02:10 PM
low oil pressure reading - fixed J33ptj97! TJ Wrangler Technical Forum 4 09-29-2006 06:31 AM
Correct Oil Pressure Reading? 99 4.0 UnsanePyro TJ Wrangler Technical Forum 2 07-24-2006 08:26 PM
Faulty Oil Pressure Reading? Milhouse TJ Wrangler Technical Forum 4 05-31-2005 03:39 PM
oil pressure reading GhostDog YJ Wrangler Technical Forum 3 03-20-2005 11:58 AM
