oil pressure high - JeepForum.com
post #1 of 10 Old 03-12-2006, 09:00 PM Thread Starter
heapofjeep
oil pressure high
my oil pressure is high after changing my oil on my 91 4.0 and durring the search i found out it may be my oil pressure sending unit, where can i find this in the engine bay? does anyone have pictures? Thanks
91 White wrangler 4.0 31s
89 black yj, 6cyl, R.I.P
heapofjeep is offline
post #2 of 10 Old 03-12-2006, 09:24 PM
Grubbi
Grubbi's Avatar
You say this started after changing the oil, you didn't put too much oil in did you?
'99 TJ 4.0, 3" Rusty's Lift, 1" Tera Body Lift, 33"s on Cragar Soft 8's
Warn XD9000i
Grubbi is offline
post #3 of 10 Old 03-12-2006, 09:26 PM
mfw1fan24
Check the sending unit
Most of the time when they go bad the pin the gauge
Its on the side of the motor by the distributor
mfw1fan24 is offline
post #4 of 10 Old 03-12-2006, 09:31 PM
jeffy
jeffy's Avatar
The sending unit is on the passenger side of the engine. Next to the distributor. It should look like a 1" round cylinder with one wire going to it. WHen you remove it leave the 90* bend piece in the block.
*** www.4BangerJP.com ***
jeffy is offline
post #5 of 10 Old 03-13-2006, 12:24 PM Thread Starter
heapofjeep
i dont belive i put too much oil in. Im new to jeeps but done oil many times. the oil level is above the safe line. how much above the safe line is too much?
post #6 of 10 Old 03-13-2006, 03:07 PM Thread Starter
heapofjeep
would anyone be able to tell me if i have to drain some oil, it would be messy but wouldnt be the first time and wont be the last.
Thanks
post #7 of 10 Old 03-14-2006, 05:19 AM
tookie
Holds around 5 quarts, but too much won't change pressure
tookie is offline
post #8 of 10 Old 03-14-2006, 05:24 AM
Pontiac Freak
My 95 hold 6.5 quarts according to Autozone. Seems like a lot.
Pontiac Freak is offline
post #9 of 10 Old 03-14-2006, 06:00 AM
claybob
claybob's Avatar
6.5 quarts is alot. I think they got something wrong there.
04 LJ, 4" RC Susp Lift, 35x12.50 Mickey Thompson Baja Claws
claybob is offline
post #10 of 10 Old 03-14-2006, 07:41 AM Thread Starter
heapofjeep
thanks for the info guys, my pressure is lessoning as the oil breaks in i think, now to work on the coolant its not getting up to temp. Im going to change the coolant it looks pretty old.
Oil Pressure.... too high? MikeyJ YJ Wrangler Technical Forum 13 05-09-2009 10:41 PM
Restart Idle High and High Oil Pressure bringbackphish YJ Wrangler Technical Forum 2 12-09-2008 08:46 PM
high oil pressure Sunvista TJ Wrangler Technical Forum 5 07-22-2008 05:03 PM
High Oil Pressure Tom Kuhn YJ Wrangler Technical Forum 12 04-28-2007 08:14 AM
Very high oil pressure BigD1634 YJ Wrangler Technical Forum 3 11-28-2001 06:40 AM
