Oil pressure gauge - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Oil pressure gauge
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineZONE 4.25" combo lift for TJ available at Rockridge4wFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRI
Unread 03-14-2013, 07:36 PM   #1
myers1122
Oil pressure gauge
Oil pressure gauge not working
Out new sending unit in it and still no luck
Any one run across this issue before ?
It's a 95 yj with a 97 motor in it 2.5.
myers1122 is offline   Reply With Quote Quick reply to this message
Unread 03-15-2013, 04:54 AM   #2
Old4X
1990 CJ7
Have you checked the FAQs?
VERY common problem. Start by pulling the gauge cluster assembly. Remove the gauges and clean the contacts for each gauge. Reassemble with some dielectric grease.
Clean the ribbon connector assy and the ribbon that connects th gauges to the wiring harness. Polish to bright and shiney, but be careful, the conductor is very thin.
You may have to do it several times before all works properly
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
