oil pressure fluctuating - JeepForum.com
post #1 of 14 Old 10-10-2009, 04:49 PM Thread Starter
yjjustforme
hey guys i got a ?. In the morning i start the jeep and the oil pressure guage reads like 60 and everything is fine and dandy. its when i have been driving it around for a while and the engine is warmed up and its warm outside that the guage will drop to around 40 or lower while idling. do u guys think its the oil pressure sending unit? if so i should just be able to do a quick swap of the "faulty" one right. (its right above the oil filter right?). thanks in advance.
Just let me get my hands on the guys that decided to install torx bolts on JEEPS!
yjjustforme is offline
post #2 of 14 Old 10-10-2009, 05:26 PM
tobias94yj
Hillbilly Member
tobias94yj's Avatar
mine does that too. maybe it is a problem but I attribute it to the fact that once the oil warms up it thins up some so when you drop back down to idle the oil pressure lowers
To view the NEW
click here!!!
tobias94yj is offline
post #3 of 14 Old 10-10-2009, 05:44 PM
DEERSLAYER94YJ
you are correct the sending unit is right above the filter, all in all your looking at a $5 part that takes 2 min. to install, worth trying it in my opinion.
Nightcrew Member #093
DEER--- It's whats for supper!!
DEERSLAYER94YJ is offline
post #4 of 14 Old 10-10-2009, 06:47 PM
wanabejeeper
1987 YJ Wrangler
That is perfectly normal. Cold oil has a higher viscosity resulting in a higher pressure at cold start up. Once its warmed up it will drop. 40 at idle is pretty good pressure. Around 20 at idle is normal for high milage +100k.
Less then 10 at idle and you need to have a good look at your main bearings
wanabejeeper is offline
post #5 of 14 Old 10-10-2009, 07:27 PM Thread Starter
yjjustforme
k thanks guys my odo says 183k but i have had larger sized tires for YEARS so i pretty sure its way off. also i heard its ok to run 10 40 oil in my jeep when it has that many miles.
post #6 of 14 Old 10-10-2009, 07:27 PM
Jeeeeeeeeeeeeep
Same here.
1991 Jeep Wrangler 2.5L, 5 speed
2003 SVT Cobra Supercharged 32V 4.6L, 6 speed
Jeeeeeeeeeeeeep is offline
post #7 of 14 Old 10-10-2009, 08:05 PM
godzirra
mine idles at about half untill i press the gas pedal then it stays at 80 but comes back down once i stop. it goes up and down depending on how much gas i give it
U.S.M.C. : Travel agents to allah
godzirra is offline
post #8 of 14 Old 10-10-2009, 08:09 PM
Fhajad
Mine sits higher while cold. But on really hot days and such, it'll idle at 20 then under load I'm always at 40.
Fhajad is offline
post #9 of 14 Old 10-10-2009, 08:14 PM
yellow2kgt
That is normal. Once the oil is warmed up the oil pressure should drop some at idle. As long as the pressure builds along with the RPMs you are fine. One of the local engine builders told me many years ago that as long as you have about 10 psi per 1000 RPM all is good. This is coming from a Ford guy that mainly builds race engines.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #10 of 14 Old 10-10-2009, 09:27 PM
XsaltlifeX
Normal, don't worry at all!! Mine does the same thing!
XsaltlifeX is offline
post #11 of 14 Old 10-10-2009, 10:05 PM
4.7stroker
Normal,
In 96 the Mustang changed from a "real" guage to a guage that is nothing more than an idiot light wih a needle. People wouild see the guage moving and think that there was a problem then head off to the dealer so then the dealer would have to convince the customer there was nothing wrong.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #12 of 14 Old 10-10-2009, 10:27 PM
plac
my 93 with 70k miles idles at 65psi (cold), and normally stays at 60psi at all times.
2015 Subaru WRX
plac is offline
post #13 of 14 Old 11-13-2010, 04:35 PM
msfitnrtz
Whew! this happened today and glad it might be normal although took a while for idle to finally level off. I will still monitor & look at changing the oil and sensor.
Love these forums!
Thank You!
1990 YJ Wrangler 4.2L
My first Carb & Auto Jeep!
SOLD to BF
2012 JK Unlimited Rubicon!
Auto
msfitnrtz is offline
post #14 of 14 Old 11-13-2010, 07:47 PM
jay-h
The thing to look for is a change in oil pressure behavior. All engines have their individual quirks.
jay-h is offline
Fluctuating Idle funky_boss23 TJ Wrangler Technical Forum 3 12-03-2009 07:03 PM
Oil Gauge Fluctuating. fox86 TJ Wrangler Technical Forum 1 05-14-2009 05:09 PM
HELP PLEASE: Oil Pressure Fluctuating wildly Oman Jeep TJ Wrangler Technical Forum 8 01-16-2008 03:15 PM
Fluctuating Oil Pressure Reading Sammer YJ Wrangler Technical Forum 4 03-14-2007 02:10 PM
Voltage Fluctuating. Help me out! xpanterax YJ Wrangler Technical Forum 5 12-06-2006 03:07 PM
