oil pressure - JeepForum.com
post #1 of 7 Old 06-21-2002, 05:58 AM Thread Starter
bonehead99
bonehead99's Avatar
oil pressure
I'm not sure if this is normal but maybe someone can tell me. My oil pressure seems to drops down to about 20psi after running 60+ mph for more than 40 minutes, it happens when I put it in park. If this isn't normal what can I do? Also my jeep is running hot 210-220 would this cause the oil to get to hot? I'm running 10w-30, should I change to 10w-40 or intall a oil cooler? Thanks for the help!
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 7 Old 06-21-2002, 06:20 AM
Bob K
Bob K's Avatar
You've got the right ideas. Oil does thin out at high temperature. I run 10-40 year round in New England. The other factor to consider is how reliable and accurate you oil pressure gauge and sender are. Factory Spec for oil pressure in the 4.0 is 13 psi at idle, 37 - 75 psi above 1600 rpm. I would try to get that operating temp down anyway.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 7 Old 06-21-2002, 06:34 AM Thread Starter
bonehead99
bonehead99's Avatar
I'm going to flush the radiator, change upper and lower hoses, replace drain plug, and thermostat. Anything I'm missing? I what temp thermostat should I get? I was thinking 190 degree....
post #4 of 7 Old 06-21-2002, 08:56 AM
rick_chicago
I believe 195 is OE spec for the 2.5L. Not sure about the 6.
I'd certainly switch to 10W-40 during the summer months in Ohio. The current tempatures are pretty high for 30.
89 YJ 2.5L 5-Spd
rick_chicago is offline
post #5 of 7 Old 06-23-2002, 10:31 AM
Bob K
Bob K's Avatar
Same with the temp as oil pressure. If you have a reading above or below normal check the accuracy of the gauge before you drop a lot of money fixing "problems" that might not exist. Also check your fan clutch to be sure it is engaging as needed. 195 degree is recommended. My Jeep ran fine for years with a 180, but if there is an overheating problem a lower temp thermostat will not fix it, it will only give you a bit more time before it heats up. Also clean the outside of the radiator for maximum cooling.
Happy Jeepin'
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Bob K is offline
post #6 of 7 Old 06-24-2002, 05:28 AM Thread Starter
bonehead99
bonehead99's Avatar
I flushed the radiator and it seemed to help, the temp went down about 5 degrees. I still have to change the thermostat. How do I check the fan clutch bearings? My fan runs as soon as the engine starts.
post #7 of 7 Old 06-24-2002, 05:53 PM
Bob K
Bob K's Avatar
It has been said, Though I've never dared try it, that the way to test it is to warm up the engine then hold a piece of cardboard against the fan. If the fan stops turning you need to replace the clutch assembly. I would suggest warming up the engine thoroughly then shut down the engine and try to spin the fan by hand. You should feel significant resistance. If the fan spins freely the clutch is shot. This would be a cause of the engine running hot in traffic, but cooling down on the highway.
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Bob K is offline
Oil Pressure ? leaptj YJ Wrangler Technical Forum 15 05-09-2011 10:13 AM
Possible to convert '03-'06 oil pressure gauge to display actual oil pressure? Night Wolf TJ Wrangler Technical Forum 40 05-03-2010 11:48 AM
2.5L oil pressure 94mangler YJ Wrangler Technical Forum 9 04-30-2010 03:22 PM
oil pressure toates89 YJ Wrangler Technical Forum 2 04-30-2010 03:18 PM
Oil pressure LaJeeper TJ Wrangler Technical Forum 11 04-06-2006 09:58 PM
