Oil Leak (drip) - JeepForum.com
post #1 of 7 Old 10-19-2001, 03:13 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Oil Leak (drip)
I have a slight oil leak, it is sort of a drip because it happens a little here and a little there, i am wondering what it could be though, i mean there is a little oil around the place where you put oil, the engine block and some of the oil pan looks like there was oil on it, and down where the oil pan is where the motor connects to the tranny, it looks like there is some oil build up and it drips off that mostly. I am not sure though please help out.
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 7 Old 10-19-2001, 05:58 PM
Nightclaw
Jeeps don't leak - they mark their territory!
Try this. Park the Jeep over a sheet of cardboard. Wait for a drop of oil to appear, then climb underneath and look directly above where the drop of oil is on the cardboard. From there, you can determine the source of the leak, either by seeing the leaking part or by following the leakage trail up to the source. Good luck!
'94 YJ Sahara Hardtop
4.0L / AX-15 / Stock NP231 / Stock D30 (open) / D60 (35-spline, Detroit locker, Moser axles) / rear disc brakes / 4.56 gears / Advanced Adapters SYE & CV Shaft / 33" BFG MT-KM's / Thorley Header / Magnaflow Muffler / BesTop Flares
Nightclaw is offline
post #3 of 7 Old 10-19-2001, 10:36 PM
JeepTodd
I recently purchased a 87 Wrangler that had an oil leak also. I found that it was coming from the valve cover. The valve cover does not have a gasket and instead uses a sealant type material. You can buy the correct sealant from the dealer for about $5.00 and if you have basic tools replace the gasket on the valve cover and hopefully stop the leaks. Mine was coming from the back of the valve cover and was also dripping onto the ground between the engine and transmission. Good Luck
1987 YJ, 4" lift, 33 x 12.5's, 4.2l
2001 TJ, 4" lift, 33 x 12.5's, 2.5l, air raid intake, air raid TBS
JeepTodd is offline
post #4 of 7 Old 10-20-2001, 12:30 AM Thread Starter
bigjeep39
bigjeep39's Avatar
see, i have done the cardboard and it is coming from where the engine connects to the tranny, and the valve cover, i have already worked on that. I wonder if maybe its the oil pan gasket
1998 TJ
post #5 of 7 Old 10-20-2001, 07:36 AM
glm 87 wrangler
I rember the days of my famous VW bugs. I had a 71 super beatle.It was very fast after the
rebuild job. It was so fast and I was so young
it only lasted 2 weeks.But it did not leak a drop of oil.Bugs and jeeps are made to leak oil. Least thats the wayI looked at it.I tried the sealent on the valve cover it leaked I used the cork valve cover gasket it leaks a little.And i only have a little over 35,000 on the rebuild.So if the leak is not
that bad dont worry about it.But rember thats my view of the 4.2 and 4.2 only...so save the money till the leak gets worse if you cant find it soon..
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #6 of 7 Old 10-20-2001, 10:49 AM
bob91yj
I keep my engine clean just to spot little problems like this before they become big problems, almost anal about it probably. I had a leak that ended up dripping from the bottom of the bellhousing. At first I thought it might be coming from the rear main seal, further investigation revealed that it was a coming from the distributor, boy was I releived. It ran down the side of the block from the distributor to the oil pan rail, along the rail and down the bell housing where it finally dripped off. This was on a 4.0L, hope yours is something simple too.
I try to follow the K.I.S.S. theory when diagnosing problems-Keep It Simple Stupid.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #7 of 7 Old 10-21-2001, 08:19 PM Thread Starter
bigjeep39
bigjeep39's Avatar
hey thanks to all
i am tightening bolts and it seems to help
1998 TJ
drip drip cake TJ Wrangler Technical Forum 2 05-29-2008 07:56 PM
Drip, Drip, Drip... kevin A Whitler YJ Wrangler Technical Forum 6 05-19-2008 09:01 PM
oil drip Mike Davis YJ Wrangler Technical Forum 7 12-24-2006 11:39 AM
Drip drip it goes tjslawny TJ Wrangler Technical Forum 4 12-11-2003 02:03 PM
A/C drip drew622 TJ Wrangler Technical Forum 2 07-29-2003 08:28 AM
