oil leak after new main rear seal - JeepForum.com
post #1 of 9 Old 02-15-2015, 06:01 PM Thread Starter
daltonfarr69
1987 YJ Wrangler
I replaced my main rear seal last week after living with a oil leak for years. Afterwards the motor developed a squeaking noise coming from the under the engine at all rpms. This squeak went away after a day of driving the jeep around. Now the jeep still leaks oil and i might even say worse than before! I followed all the directions posted from old threads here on the forum and also watched several youtube videos beforehand.
has anyone heard of the squeaking after the new rear seal?
I wonder if that was the sound of the new seal getting burned up
daltonfarr69 is offline
post #2 of 9 Old 02-15-2015, 08:49 PM
Jeepsr4me
sounds are very hard for us to tell ya what it was... But since its leaking again, you will need to change it again. There is a double lip seal that rides on another spot on the crank so its less likely to leak.
Jeepsr4me is offline
post #3 of 9 Old 02-16-2015, 06:05 AM
Mike Romain
First I would take a clean rag, run the engine for a few minutes, shut it down and wipe the rag across the rear of the head just below your valve cover. If the rag finds oil, you have found the first leak.
The leak getting worse, could be a failed rear main install. Did you have it good and clean so it would stick where you put the dabs of RTV?
Mike
Mike Romain is offline
post #4 of 9 Old 02-16-2015, 03:57 PM
kahanabob
horror story, i know because i went thru it. are you positive you installed the seal correctly? one side of it goes toward the front of the engine. it is very easy to put the the top half in backwards. also the pan gasket at the rear of the pan on the 1/2 circle (where it dips down) has to line up perfectly so it seats into the groove on the engine. took mine apart twice and stilled leaked, sold it!!
good luck..........
kahanabob is offline
post #5 of 9 Old 02-17-2015, 08:58 AM
bck4more
1987 YJ Wrangler
Ive heard many times over of people having a rear main leak and go to replace it many of time and still leaks so what ive gathered is if its just a drop here and there id leave it imo
1987 4.2 automatic, 33" Pro Comp, 2100MC, nuttered, SOA, SYE,TW driveshaft
bck4more is offline
post #6 of 9 Old 02-17-2015, 12:40 PM
kahanabob
Good advice!!!
post #7 of 9 Old 02-17-2015, 04:50 PM
mickcollinsb16b
good luck..........
very important. the seal is directional. and i dont mess with the vatozone, Napa seals. just go to the dealer for something that important. ive done 3 (2-4.0's and a 4.2) and none of them leaked. one time i bought a felpro or some other aftermarket seal cause the dealer was closed and i did not get it in successful. it kept riding more on the side of the block which is sharp and it cut it. if you pm i will give you full proof method if you want. no leaks.
RoknRoll, beer & Jeeps
mickcollinsb16b is offline
post #8 of 9 Old 02-17-2015, 09:16 PM
YJ8
Welcome to the club
You are not alone, I had to do mine 4 times before it sealed perfectly, but this is not a sad story, it has been 14 years since, with no oil leaks . You will get there too.
As stated, the seal is directional but I found the larger problem is the 4 piece oil pan gaskets are a PITA, use ample RTV in the rear corners and cross your fingers, keep the faith, one of these times you will nail it.
Yj-8
YJ8 is offline
post #9 of 9 Old 02-18-2015, 01:26 PM
Leadmine
1979 CJ5
Another note on the pan gasket, if you don't have one go rent/buy/borrow an inch-lb torque wrench. I did a real seal and pan gasket on the 304 in my CJ. Tightened the pan bolts with a 1/4 drive ratchet tying to be careful not to squish the gasket (I think specs call for 11 to 16 in/lbs, not much). Squished it anyway, fired the engine and it POURED. Luckily we have an old school mechanic at work that I was telling my delima to and he loaned me an inch-lb wrench. I used the wrench to factory specs and *knock on wood* my engine hasn't leaked a drop of oil in about 8 months....from the pan or rear seal anyway.
1979 CJ-5 Chevy Hugger Orange paint, 304/T-18/Dana20, 4" Procomp on 33x12.5
Leadmine is offline
