oil leak - JeepForum.com
post #1 of 3 Old 01-28-2012, 08:48 PM Thread Starter
91YJ-98TJ
oil leak
so i was out wheeling last weekend and im pretty sure i blew out my rear main seal. leaked a bunch of oil and even sucked in some mud into my oil pan. After i got it back home i replaced my rear main seal, bought a new oil pan (mine had some nasty looking dents anyway) and a new oil pan gasket. tore it all apart put it all back together with the new stuff and it still leaked at the back of the oil pan. took it apart again and put a new oil pan gasket on and just cranked it up and its still leaking in the same spot. Tomorrow im gonna try it yet again and this time buy another new rear main seal too. I was wondering if yall have any other suggestions or tips where you think i could have gone wrong, because i really dont want to take it to a mechanic that just feels like giving up haha
91YJ-98TJ is offline
post #2 of 3 Old 01-29-2012, 10:28 AM
moonshinefuel
If you sucked mud into your oil pan, you may have worn out the mains for the crankshaft resulting in too much play, and causing your rear main to leak. Just a possibility, that's all. You could pull the caps and plastigauge, and repair the mains if that's what it turns out to be.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 3 Old 01-29-2012, 10:38 AM
pasinbuy
Dude,, double posting is kind of a no, no.
http://www.jeepforum.com/forum/f12/s...l-pan-1321002/
You might want to delete this thread.
pasinbuy is offline
leak , oil pan , oil pan gasket , rear main seal
Pinhole leak in radiator--Alumaseal/Bar's Stop leak? JEEP97TJ TJ Wrangler Technical Forum 16 06-11-2010 06:01 PM
Water Leak (not the regular FRONT leak) jrs948 TJ Wrangler Technical Forum 1 01-18-2010 06:05 AM
Engine oil leak! Front diff sweatl leak Mr.Unlimited JK Wrangler Technical Forum 11 09-22-2009 08:49 PM
Tranny Leak, any common place for a jeep to leak jb1dsl TJ Wrangler Technical Forum 6 03-23-2006 10:09 AM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 12:46 PM
