oil leak ??? - JeepForum.com
post #1 of 3 Old 04-02-2010, 02:08 PM Thread Starter
striperman101
Just got a 1990 jeep yj 1990 , put in new clutch , hoses belts ect. engine gaskets , oil still leaks out of top of distributor - weep hole . Got a new distributor , same thing , i checked crank case vent - pvc valve . i am stumped . I need help ?????????
http://www.jeepforum.com/forum/f12/oil-leak-1004606/
striperman101 is offline
post #2 of 3 Old 04-18-2010, 12:36 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Anybody care to provide some input?
Thanks,
Joe
Joe Dillard is offline
post #3 of 3 Old 04-18-2010, 02:38 PM
yankeegp0820
I have a bad oil leek to and i dont know if its the vavle cover of the rear seal. The oil drips on the head bolt by the last nut and when i turn it runs down the block. Im not sure how to fix it correctly if theres a certain way to tighten them or what. If i fix this and see if it is still leeking then i guess it might be my rear seal. I havent looked at the distribitor thow i need to check it. I hope we can get it all figured out.
yankeegp0820 is offline
Pinhole leak in radiator--Alumaseal/Bar's Stop leak? JEEP97TJ TJ Wrangler Technical Forum 16 06-11-2010 06:01 PM
Engine oil leak! Front diff sweatl leak Mr.Unlimited JK Wrangler Technical Forum 11 09-22-2009 08:49 PM
Oil Leak..Water Leak...Comp. meltdown tbrkek JK Wrangler Technical Forum 30 10-07-2006 02:47 PM
Tranny Leak, any common place for a jeep to leak jb1dsl TJ Wrangler Technical Forum 6 03-23-2006 10:09 AM
rear main seal leak and exhaust leak? paroxysym TJ Wrangler Technical Forum 6 01-30-2006 12:46 PM
