Oil Flow From Rear Axle - JeepForum.com
post #1 of 4 Old 07-01-2011, 10:28 PM Thread Starter
YJSlave
Driving my Jeep to the trail and the rear axle (Rodeo D44) was puking differental oil all over the jeep behind me driving down the highway. I recently removed the abs sensor out of the top of the pumkin and fabed up a plate which I drilled and tapped and added the factory vent to use as the axle vent tube. Rodeo's come from the factory with a vent coming from the diff cover which I removed and blocked with a small bolt with RTV. What would cause the oil to come out of the vent now on the top of the pumkin? Could this just be from the gears throwing oil and it making it's way up the vent hose?
I also ran a new vent hose under the jeep along the frame and high into the engine compartment with a small filter on it, could this cause the problem? Help
YJSlave is offline
post #2 of 4 Old 07-01-2011, 10:44 PM
deathtrap
No clue on the leak, but can you tell me more about what you had to do to swap in the rodeo d44. I want
to put one in mine.
deathtrap is offline
post #3 of 4 Old 07-02-2011, 11:27 AM
Noltz
YJ Wrangler
If the new vent is directly in line with the ring gear, or even close to it, it's entirely possible at high speeds the fling off the carrier/gear is getting thrown and pushed up and out your vent tube.
my suggestion is to pull the cap of the OE vent, cap your ABS cover, and run the vent line in it's original place.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #4 of 4 Old 07-02-2011, 11:15 PM Thread Starter
YJSlave
Thanks for the replies. Mounting the axle was easy. The spring mounts basically line up, about a 1/4" wider than the YJ axle so the spings push out ever so slightly with my lift. For the brakes you need to get adaptord for metric to sae or cut the rodeo hard line and reflare with the metric fitting. That's what I did. Lastly if you run a stock driveshaft buy a standard D44 pinion yoke and put it on.buy 6 lug wheels and done. Then buy a waggy front axle and drill the spring pads 1/2" closer and mount that axle for a matching front, plenty of threads on the waggy swap.
As for the mounting to stock location for the vent, that's too easy! I really wanted to get it out of the way and not have to drill and weaken the Solid diff cover I bought to protect the rear gears.
Anyone else?
YJSlave is offline
Is it water flow or air flow? planedog YJ Wrangler Technical Forum 3 09-08-2010 04:48 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 10:27 AM
Solid Axle Hd 44 Rear Axle Assembly SuperWade2 TJ Wrangler Technical Forum 128 06-05-2009 01:01 AM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 03:23 PM
Flowmaster 40 Series Original flow or Delta flow Dctjwrangler01 TJ Wrangler Technical Forum 2 06-08-2004 09:53 AM
