oil filter leak - JeepForum.com
post #1 of 3 Old 03-09-2013, 07:13 PM Thread Starter
salsomano1a
oil filter leak
i have a 91 4.0 that has a leak on the oil filter or around the base that holds the filter,i already replace the filter with a STP 3/4 x 16 thread like its says inside the engine, and seal the base that holds the oil filter,oil pan gasket its new and also the valve cover gasket have been replace but stills leaks,all help will be appreciated, thanks
salsomano1a is offline
post #2 of 3 Old 03-09-2013, 08:36 PM
Old4X
1990 CJ7
Are you sure the leak is from the filter base? Is it a pressure leak or a drip/seep?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 3 Old 03-09-2013, 09:25 PM
rubinscube
I too had what I thought was a filter leak, in my 1988, but it was from the distributor seal
rubinscube is offline
