oil drip - JeepForum.com
post #1 of 8 Old 12-22-2006, 09:49 PM Thread Starter
Mike Davis
oil drip
I tried this new thread b4 but it went away. I have a 4 cyl, 5 spd, 1992 YJ w/ 145k mi. i recently cleaned the valve cover (in the dish washer...ouch) replaced the gasket and sealed it with copper high temp silicone sealant. No leaks from there now. The rear main was repl about 5 or 6k ago. i still get a drip or 2 overnight from somewhere. The seal between the tranny and transfer case was recently replaced to stop the dripping of clear redline syn 75w90 gear oil from the tranny. Now I see the engine (black) oil drips in the morning. Any suggestions??? Another rear main??? NOT...I'll just add oil. Oil pan bolts??? Any more obvious suggestions??? Oil leak stop additive??? Synthetic oil??? 15W40 oil??? Mike
Mike Davis is offline
post #2 of 8 Old 12-22-2006, 10:01 PM
Burnerman
Burnerman's Avatar
A drip or 2? If I could be so lucky! only thing I could suggest is a cheap can of brakeclean. After you park it clean the bottom of the engine with the brakecleen and then check for oil in the morning and see where it's coming from.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 8 Old 12-22-2006, 11:03 PM
bobbert350
bobbert350's Avatar
dont change to synthetic.. where is it comming from it could be the timing chain gasket or the oil filter..they are just 2 options
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #4 of 8 Old 12-22-2006, 11:11 PM
tuckinauster
tuckinauster's Avatar
wow only a drop or two must be nice. mine leaks oil from places it didn't even know it had
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Itís a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #5 of 8 Old 12-22-2006, 11:22 PM
JeepTransformer
Is it your diff??
2nd GEN CUMMINS, Manual, Stock
brraaap
JeepTransformer is offline
post #6 of 8 Old 12-23-2006, 08:03 AM
King03Kev
King03Kev's Avatar
1987 YJ Wrangler
If you just replaced your valve cover and pan gasket try to retorque to spec. After a couple of times heating and cooling maybe a bolt or two came loose.
kevyj87 '87 I6 5spd, 215,000+ miles, Herced, Nuttered, Weber, HEI, RE 4", 1" BL, 4:11's, np231, 33x12.5's, SYE & shaft, 1" brown dog mm, home made bumpers front & rear, Ramsey 8,000lb winch
King03Kev is offline
post #7 of 8 Old 12-24-2006, 11:35 AM
Bad_Dog
Why do you say, don't change to synth? When I bought mine, the PO had receipts out the wazoo for the Jeep and what all work had been done on it, but none stated what kind of oil he used. I called him up and asked, and he said that he didn't know, just whatever 'the shop' puts in it. Greaaaat.
I put Amsoil in mine back in April, I think. Since then, I've only driven it about 2k miles - Amsoil is good for 7k. I mostly drive it in the winter, hence the small # of miles put on it.
I do have oil drip on mine, but it's coming from in/around the drain plug. I'm suspecting the seal around the oil pan needs replacing. I did see a fair amount of red sealant around where the gasket would be, so I don't know if it was a shotty job done "way back when", or it's just that time... I have probably about four 'drops' drip out after I park it.
When I put the Amsoil in, the oil coming out was extremely dirty, so I had them put in 0W to clean it out and then put in the Amsoil and a new filter.
And BTW, that's a good pic of you and Norton. It's rare that I've seen him smile in a pic. ;-)
OlllllO 2013 Wrangler Sahara Unlimited
[]lllll[] 1991 Wrangler Renegade, 4.0L Auto (Retired 2013)
Bad_Dog is offline
post #8 of 8 Old 12-24-2006, 11:39 AM
bobbert350
bobbert350's Avatar
all im gonna say is that im glad you know who jim norton is he is amazing in my book...also the only reason i say dont change to synthetic is that alot of time the synthetic oil will find places to flow threw.....happened on my jeep and my buddies truck ran fun with reg oil but as soon as i but the syn blen in there i had a oil leak that i had to fix....kinda strange id say....but do what u want thats just my 2 cents....
Mysterious Drip xjGeoff18 TJ Wrangler Technical Forum 2 08-26-2009 07:25 AM
drip drip cake TJ Wrangler Technical Forum 2 05-29-2008 07:56 PM
Drip, Drip, Drip... kevin A Whitler YJ Wrangler Technical Forum 6 05-19-2008 09:01 PM
Drip drip it goes tjslawny TJ Wrangler Technical Forum 4 12-11-2003 02:03 PM
A/C drip drew622 TJ Wrangler Technical Forum 2 07-29-2003 08:28 AM
