oil drain plug won't loosen or tighten. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > oil drain plug won't loosen or tighten.
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread Today, 06:52 PM   #1
jchandler926
I went under jeep to change the oil and the bolt will not come out. It will turn either way but doesn't tighten or come out. Can I drill out the bolt and replace with larger size? Or do I have to replace the whole oil pan?
jchandler926 is offline   Reply With Quote
Unread Today, 06:57 PM   #2
littleredjeep
No you dont have to put in a new oil pan. You can drill it out and put in a heli coil (sp?) in it and go to the next size drain plug. If you go to a decent parts store they can fix you up with the goodies for it.
88 YJ 4.2, 5-speed, 4"RC lift, 5/8 booms, herced tub, and cavi seats
My build thread
http://www.jeepforum.com/forum/f12/littleredjeep-build-669382/
_____
/| ,[___],
|--L --[]lllll[]-
()_) ()_)-o-)_)
littleredjeep is online now   Reply With Quote
Unread Today, 07:01 PM   #3
jchandler926
Ok that's what I was thinking, but every mechanic is trying to say replace pan. I'll search auto parts store tomorrow. Thanks for the help.
Unread Today, 07:02 PM   #4
Old4X
1990 CJ7
Slide a heavy duty putty knife under the bolt head. Put pressure on the bolt and un screw it, it will come out.
Go to NAPA and get an oversize drain plug, and make sure to use a new gasket/washer for it.
Rust free YJ for sale. Need more room in barn.
Old4X is online now   Reply With Quote
Unread Today, 07:46 PM   #5
jay-h
They make expanding rubber drain plugs for people in your situation.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline   Reply With Quote
Unread Today, 07:57 PM   #6
dukeryder
The oil Drain Plug has been stuck in my Mother's BMW 325IS for like 10 years; you can either bring it to a quick lube and they'll suck the oil out or you can buy the suck out kit at Harbor Freight to DIY. They've been selling cars for years with no drain plug in the sump.
I'd start with the Putty Knife trick first though.
dukeryder is offline   Reply With Quote
