Hey All,
Jeep started running crappy the other day so I decided to give all the usual tune up things the once over. While checking spark plugs I noticed the distributor cap was tilted due to one of the screws being stripped. I removed the distributor so I could tap the screw hole a size up and noticed there was oil residue inside the housing. I also noticed there was a little up and down play in the shaft but not sure if that is normal. Finally there is some wear on the gear. I have pictures of the residue and then gear wear below. Please let me know what you think.
Thanks :cheers2:
Thanks :cheers2:
