Oil consumption problem... where to start?? - JeepForum.com
post #1 of 13 Old 06-11-2006, 10:53 PM Thread Starter
MayorMcCheese
So it seems that I have a slight oil consumption problem.
I seem to be averaging about 1 qt. loss per week or so. About 3 weeks ago it was in at the garage and I had them replace the valve cover and gasket because the valve cover was cracked and it appeared to be leaking oil. Fast forward to last week and I notice that the oil pressure has dropped and that my "diesel ticking" had gotten a little louder, checked the oil and sure it enough it was 3 qts. low!!! And I'm not dripping on the driveway anywhere.
So for now it has some 20w-50 in it and my normal ticking is a lot quieter and the engine seems to be running better then ever. I would think that my obvious first step is to check the valve cover gasket out and see that it was replaced correctly, but after that what is next?
If I was burning almost a quart every week, then wouldn't the exhaust be pretty black?
Sorry for the long post, but I wanted to give as much info as possible to get a good lead on where to start.
TIA
-Evan (YJ noob)
1990 YJ 2.5L
Stock everything... for now.
MayorMcCheese is offline
post #2 of 13 Old 06-11-2006, 11:26 PM
mp3coupe
mp3coupe's Avatar
Is the ground underneath the jeep dry now? If yes then your burning it.
How many miles are on it?
Pull the plugs and see if they're black.
What oil on a plug looks like
http://www.classictruckshop.com/club...park/plugs.htm
edit
A quart a week!!! How many miles are you doing a week? Are you pulling high R's?
mp3coupe is offline
post #3 of 13 Old 06-11-2006, 11:35 PM Thread Starter
MayorMcCheese
edit
I probably do an average of about 350-400 miles per week as an estimate, maybe a little less some weeks.
There is definately some oily spots here and there around the engine bay and underneath, but I can't really tell what is new and what is old.
I'm thinking my first step may be to clean everything up really good to see what spots form after that.
-Evan (YJ noob)
1990 YJ 2.5L
post #4 of 13 Old 06-12-2006, 02:29 PM Thread Starter
MayorMcCheese
Any other suggestions about how to attack this problem?
It is possible to have an oil leak that does not drip on the ground correct?
-Evan (YJ noob)
1990 YJ 2.5L
post #5 of 13 Old 06-12-2006, 03:39 PM
flame0086
If you're exhaust is blue, then your engine is burning the oil. I just recently had oil leaking from the rear main seal, but I didn't notice it until I had my jeep on the drive way instead of the gravel. It was only a couple of drops, but knowing my jeep it was enough for me to get under there and see if it was something big. A few minutes later I put 3 quarts of oil in it and call up the shop that put in this new engine.
flame0086 is offline
post #6 of 13 Old 06-12-2006, 05:18 PM Thread Starter
MayorMcCheese
I'm going to start watching closely, but I remember when my Jetta used to burn oil and my exhaust from the Jeep looks nothing like that.
-Evan (YJ noob)
1990 YJ 2.5L
post #7 of 13 Old 06-13-2006, 07:17 AM
vdubstreets
take engine degreaser, clean your whole motor block and everything, then periodicly check where you see oil build up. im in the same area as you im looking for a leak and i think i found it. to the left of the distributor is where a 'mechancial fuel pump' would be so im going to replace the gasket. its about a quart every month or 2.
vdubstreets is offline
post #8 of 13 Old 06-13-2006, 07:30 AM
I.O.A.MUD
I.O.A.MUD's Avatar
IOm having the same problem with my 1990 2.5...90000 mi. Ive cleane the motor up and can find no noticeable leaks. The exhaust is clear. The pan has a few wet spots but not near enough to account for the oil used. I tooo did a change with 20/50..this has helped some. My neat step is a compression check. any other Ideas?
1990 2.5 basicly stock
WIFES CAR 1997 Grand cherokee Larado v-8 auto
We dont stop playing because we grow old....we grow old because we stop playing!
I.O.A.MUD is offline
post #9 of 13 Old 06-13-2006, 09:33 AM Thread Starter
MayorMcCheese
It's funny that you say that because one of the places that I noticed is a little oily is in that same location.
-Evan (YJ noob)
1990 YJ 2.5L
post #10 of 13 Old 06-13-2006, 10:02 AM
vdubstreets
if you want i can show you a diagram and give you a part number for hte gasket, it was only a couple bucks offline.
post #11 of 13 Old 06-13-2006, 11:45 AM Thread Starter
MayorMcCheese
Actually I went out today and did some investigating and I think I found the source of the leak...
Of all things it appears it was a loose oil filter. It was loose enough that I hand tightened it about 1/2 turn and then got probably a full turn out of it with an oil filter wrench.
I fill her up with oil again to the "FULL" mark on the dipstick and I'm going to check it again in a couple days. I'll post back then.
BTW: I was not the one who installed the oil filter. Just so you don't all think I'm a moron.
-Evan (YJ noob)
1990 YJ 2.5L
post #12 of 13 Old 06-16-2006, 12:29 PM Thread Starter
MayorMcCheese
UPDATE: Sadly, it looks as though that was not the problem since I have leaked probably a 1/8 qt. since Tuesday for about 80 miles of driving.
Oh well, next week it goes back to the garage I guess to try and figure out this leak.
-Evan (YJ noob)
1990 YJ 2.5L
post #13 of 13 Old 10-23-2013, 09:35 PM
Swampeast2
I think mine is leaking at the valve stem seals, but how can I be sure? I've got an 1987 YJ with a 1990 2.5 L. Is it better money to just rebuild the head?
Swampeast2 is offline
2.4L Oil Consumption???? vallejojeeper TJ Wrangler Technical Forum 13 10-09-2016 06:45 AM
Cold Start Turned Into No Start...Problem Resolved...Lesson Learned... tony673 YJ Wrangler Technical Forum 2 10-02-2011 07:49 PM
94 YJ 2.5 Cold Hard start now No Start Problem UNLIMITLESS YJ Wrangler Technical Forum 8 10-28-2009 03:53 PM
fuel consumption problem lilman555 TJ Wrangler Technical Forum 2 10-31-2008 10:36 AM
Oil Consumption? HuD YJ Wrangler Technical Forum 4 08-19-2004 08:57 PM
