oil blow by - JeepForum.com
post #1 of 8 Old 11-14-2005, 10:11 PM Thread Starter
natedawg87317
oil blow by
hey guys
ive go oil blow by on the top of my vaule cover im going to replace the to vents on the top of the vaulve cover and the oil cap, but before i do do you guys have any ideas an to what else it could be. any help would be great its geting to be a pain.
thanks
nate
2005 TJ unlimited. soft top 6spd. soon to have a 2 inch lift and 32'S
restored 72 chevy long bed\yellow green metalic
natedawg87317 is offline
post #2 of 8 Old 11-14-2005, 10:41 PM
KyleS
You should have your PVC hooked up. Placing just vents ontop of the valve cover is not the answer. The PVC helps to pull exhaust out of the crankcase which is what causes your oil to break down. By saying theres oil ontop of it do you mean its leaking out your "vent"
KyleS is offline
post #3 of 8 Old 11-14-2005, 10:51 PM
CherokeeHelpMe
arrghhh.....its PCV.....Positive Crankcase Ventilation!!!!!, put in a new PCV Valve and replace all the filters air, breather, whatever. then you should be ok. the back 90 degree elbow just hooks to the breather filter and will shoot out oil into it if the PCV Valve is clogged. it does't have any chevk valves in it, but check to make sure it isn't plugged while you're there.
happy hunting.
All I Know Is My Gut Says Maybe.
CherokeeHelpMe is offline
post #4 of 8 Old 11-14-2005, 10:51 PM Thread Starter
natedawg87317
there is oil on top of my vaulve cover yes. and i think it is comeing from around the vents or the oil cap.
i dont have a pcv vaule all i have are the two vents there is no pcv vaule attached to them.
nate
post #5 of 8 Old 11-14-2005, 11:00 PM
KyleS
I'd guess the oil is coming from around your vents then. I'd replace the vent with a PVC system it does more than most people think.
KyleS is offline
post #6 of 8 Old 11-15-2005, 04:55 AM
sandman'sjeep
put in a PCV and breather.... you can switch the positions of these two... stopped my oil leak right there!!!
sandman'sjeep is offline
post #7 of 8 Old 11-15-2005, 06:49 AM
Loopmd
Your 93 has ccv not pcv. The hoses that go from your valve cover to the manifold and airbox are clogged or missing. Fix them and you fix your problem.
Redneck Jeep Club Member #30
'92 stock YJ
4.0 L
Loopmd is offline
post #8 of 8 Old 11-15-2005, 06:54 AM
wolf3902
Yup, blow out those vent lines and put some Sea Foam into the holes in the valve cover to clean out the gunk. Better to remove valve cover and clean it , but the Sea Foam works and is less time consuming. You'll need to change the oil a few days after this also.
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline
blow by....... busadave YJ Wrangler Technical Forum 3 04-05-2009 08:27 PM
a/c no blow... STUFF YJ Wrangler Technical Forum 1 08-24-2008 09:46 PM
I think I have blow-by YJames90 YJ Wrangler Technical Forum 3 03-26-2008 08:39 PM
Blow by?? Oil Everywhere 93 2.5 wrangler YJ Wrangler Technical Forum 12 08-17-2007 06:49 AM
What did I blow? J33P'r TJ Wrangler Technical Forum 15 07-21-2006 09:31 PM
