Oil in airbox - JeepForum.com
post #1 of 6 Old 02-20-2002, 12:26 AM Thread Starter
YJ boy
Oil in airbox
Hello all I am getting alot of oil in my airbox I put new pcv and air return valve? (i think thats what it is called)also all new lines and still there is oil all over the inside of my airbox bad.... why is it getting pushed in there? Please help stop the spillage thanks
YJ boy is offline
post #2 of 6 Old 02-20-2002, 05:07 PM
Dan's YJ
I'd also like to know why it does that. Mine isn't too bad, but enough to make me curious.
1994 Bronco HD
Warn 8000
2"lift, 32x12.50
Locked
Dan's YJ is offline
post #3 of 6 Old 02-20-2002, 08:21 PM
Big92Jeep
I had the same problem when I bought my YJ. When I replaced my valve cover gasket I cleand the vents inside the cover. I haven't had any problems since. I believe because of the gunk in the vents oil gets pushed up but can't bleed back down. That's why it runs over into the filter box.
My 2ó
RýCK
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #4 of 6 Old 02-20-2002, 08:40 PM Thread Starter
YJ boy
Rick,
Well I would say that would be the fix but I have a brand new valvecover "plastic one?" but I will see if maybe it could be stoped from ony about 150 miles hope thats it!! thanks
YJ boy is offline
post #5 of 6 Old 02-20-2002, 10:19 PM
Mike611
Mike611's Avatar
95 Yj, mine does it too, oh well..
Mike...
95, 2.5L, custom bumpers, Flow's, 4 inch Skyjacker Super Duty, 33x12.50 MT's, 15X10 AR 767's, Hi-lift, Funk in the Trunk( two 12 inch subs ), soon to be locked and have one of those pully things on the front.
If you are going to be a bear, be a grizzly...
Mike611 is offline
post #6 of 6 Old 02-23-2002, 12:15 AM
NOVA Jeeper56
It is said that on yj's 2.5l more that after about 75-80000 miles they start sucking oil through there. I have a 2.5 and thre is no PCV vavle it is just and elbow. I have been told it could be a number of things including lifters,piston rings etc.... If you do have a PCV vavle not and elbow you can take your line off from the intake and put on a air breather to eliminate the oil in the box. But if you only have a elbow you need the line to suck out the pressure
'94yj, rancho lift kit, 31x10.50 BFG mud's,intake,exhaust,wheels, warn 6000lb winch,lights,
bumpers/brush guard
(used to be known as BiggMike56)
NOVA Jeeper56 is offline
88 2.5l Oil In Airbox? FSTG60MAN YJ Wrangler Technical Forum 6 09-13-2009 11:34 AM
OEM Airbox ? SuperWade2 TJ Wrangler Technical Forum 7 07-28-2007 09:49 AM
Airbox? Are they the same? onlyn8v TJ Wrangler Technical Forum 2 07-15-2007 08:41 AM
Airbox geabaldyvx YJ Wrangler Technical Forum 21 02-19-2007 08:44 AM
Oil in Airbox? dabomb5756 YJ Wrangler Technical Forum 4 04-23-2005 12:35 PM
