Oh, new to me jeep. Why do you hate me? - Page 2 - JeepForum.com
post #16 of 37 Old 04-07-2013, 07:40 PM
Renegad87
1987 YJ Wrangler
jmet87yj
I think I'll saw your other thread I'll reply there so we don't hijack this one.
Renegad87 is offline
post #17 of 37 Old 04-08-2013, 01:13 AM Thread Starter
JeepingJustin
Originally Posted by Renegad87 View Post
I have the Weber on mine and it is a pain in the A$$ to tune. What model Weber is it? If you plan on trying to tune it again I can give you some advise. If your going the motorcraft route let us know how it goes.
Yeah thats what everybody tells me. Its the 34 degv? Hope I got the last part right. I'll let ya kmow how it goes, hopefully I can go to a junk yard on tuesday.
JeepingJustin is offline
post #18 of 37 Old 04-08-2013, 12:23 PM
bigsquat
did you see if the egr isnt stuck open a little, it will make it not idle when it leaks
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #19 of 37 Old 04-13-2013, 02:44 PM Thread Starter
JeepingJustin
Well found the carb, for FREE! Now I'm just waiting on my adapter kit an such.
Yea I checked the egr to see if it was suck but it wasnt. I've had that problem before an it took me forever to figure it out. But hopefully I'll have it running after tuesday.
post #20 of 37 Old 04-13-2013, 06:23 PM
bigsquat
it can take a while to figure out sometimes. i bought a car that was running of craigs list. it started running bad right away. theres was so much wrong with it i dont know how i did so well during the test drive. it had a short in the harness, 3 loose grounds, bad camshaft position sensor, burnt up cat, bad oil leaks, week crankshaft position sensor, BAD EGR, 2 other vac leaks, and after all that and more it would stall at times. it turned out to have an intermittent short in the injector in the throttle body. it took months to get right. it was worth it tho , the dam thing got 60 mpg on the first long distance drive. now its back in the 40's for some reason.
bigsquat is offline
post #21 of 37 Old 04-16-2013, 09:30 PM
LordOfTheSith
Just repeat after me Just Empty Every Pocket
LordOfTheSith is offline
post #22 of 37 Old 04-19-2013, 03:04 PM Thread Starter
JeepingJustin
Well I'm starting in on the conversion. Should have it done in a couple hours.
post #23 of 37 Old 04-20-2013, 01:13 AM Thread Starter
JeepingJustin
Well, I think I found the problem. It would seem the PO didn't tighten the 5/16th Allen head bolts in the adapter plates. So before I go any further I'll tighten it all up an try it.
post #24 of 37 Old 04-20-2013, 09:41 AM
bigsquat
it cant be that easy , can it?
bigsquat is offline
post #25 of 37 Old 04-21-2013, 12:28 PM Thread Starter
JeepingJustin
Just gotta retime it an give it a try. It might be that easy.
post #26 of 37 Old 04-28-2013, 08:15 PM Thread Starter
JeepingJustin
Now I got it running. I have an issue of it sputtering an dying while in gear. This is with the Weber carb. I'm not sure which screws are what on this thing. There is 2 on ths base, 1 by a power valve. Not sure what all the screws are an do. If I got time tomorrow I'll post up pics.
I also did bypass ecu. An changed my timing. I might not have it advanced enough?
post #27 of 37 Old 04-28-2013, 09:00 PM
Que89YJ
sounds like timing. Did you set it at 8?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #28 of 37 Old 04-28-2013, 09:04 PM Thread Starter
JeepingJustin
Also the Weber is the 36 dgec model. If that helps. Kinda at a loss.
post #29 of 37 Old 04-28-2013, 09:08 PM Thread Starter
JeepingJustin
Do the timing marks go by 2 or just 1? I pretty sure I set it at 8.
post #30 of 37 Old 04-28-2013, 09:19 PM
Que89YJ
You start at 8 and advance it. 8 is just a starting point. If you got it running try and advance it. Are you hooked up to ported vacuum for the vacuum advance?
Que89YJ is offline
