Oh, new to me jeep. Why do you hate me? - JeepForum.com
post #1 of 37 Old 03-30-2013, 07:52 PM Thread Starter
JeepingJustin
Ok, so I bought this 1990 Yj jeep wrangler. Seemed like a good buy so I decided I'd go out an buy it. Like an idiot I bought it knowing it had some "issues". Get it home an try working out the bugs an this p.o.s. wont idle for anything. First off it has a weber carb that I have no idea to tune. (any help there would be great). Vaccum leaks everywhere. Which I think I finally got fixed. But it still wont idle? Im going to do the nutter bypass soon when work permits. But I have some bone head questions about that too.
With the nutter bypass when you cut the ignition control module an splice in wires, its before the module? An from the splice I go to my dizzy splice after the plug? I hope this will help cure some of the non idle issues I'm having an get me closer to having a running jeep. Im not use to these inline 6 motors. I'm use to bare bones chevy 4x4 setups.
Any help on the carb an nutter bypass explaination would be great.
JeepingJustin is offline
post #2 of 37 Old 03-30-2013, 09:01 PM
Que89YJ
http://www.jeepforum.com/forum/f12/p...bypass-476720/
If you have the weber you already should have the nutter done. It bypasses the elctronic controls on the stock carb. You need to setup the distributor for 8 btdc. and tune from there. Setting up the carb is something I am totally unfamilar with.
Que89YJ is offline
post #3 of 37 Old 03-31-2013, 05:49 AM
jay-h
BTW, it may just be your terminology but you DON'T bypass the ignition module, you bypass the computer. The module is essential (unless you replace it with an after market setup).
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 37 Old 03-31-2013, 09:20 AM
SLCSmoker
Sounds like me 6 months ago. I was all happy I knocked the sale price down a grand (it had 'issues' too).. Course I've spent wayy more than that now but hey, its a Jeep lol. I just bit the bullet and went Howell in the end, best thing I've done so far.
SLCSmoker is offline
post #5 of 37 Old 03-31-2013, 09:36 AM
jay-h
I drove the Carter for nearly 6 years, got tired of waiting for it to die and justify the upgrade, so I did the Howell also. Had a couple of issues but it runs much better.
After I put the Howell on, I developed a main seal leak, and after looking at the worn timing chain an rather worn bearings, I spent the rest of my money on a new engine.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #6 of 37 Old 04-06-2013, 02:25 AM Thread Starter
JeepingJustin
Well still no luck on this thing running on its own power. I've done the nutter bypass, fixing all the vacuum hose leaks, put on a fuel regulator. But still this gosh darn thing don't wanna stay running. So if anybody wants to trade a mc2100 or mc2150 for a weber let me know. I just has lost my patients with that carb. I've set it back to stock settings and still no luck.
post #7 of 37 Old 04-06-2013, 06:09 AM
jay-h
Problem is probably in the carb. There is nothing really mysterious about carbs, actually since you can actually SEE everything that is happening in the carb, the problem is just about always visible in teardown. My guess is you have a clogged jet or vent passage.
It is intriguing (though understandable) that people now view carbs with such trepidation. I grew up in an era where that's pretty much all there was and it was one of the first things you learned.
Don't tear it apart willy-nilly, do some internet searching to find instructions, get a rebuild kit (though a lot of issues can be fixed even without the kit) and go ahead and do the job. It's not hard.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #8 of 37 Old 04-06-2013, 07:26 AM
SLCSmoker
Agree with the previous post. I grew up with carbs too and once they're clean, rebuilt and set up correctly they usually run great. Course there was no emissions to pass though in those days. You may want to check your ignition timing and compression too. Even the best set up carb cant make an engine run if the timing is off or the cylinders are shot.
post #9 of 37 Old 04-06-2013, 08:44 AM
UZI4U
Have a buddy help you with this: Have him/her turn over the engine while you cover the inlet of the carb with your paw making sure it's sealed. Do this a few times. It might flood it out, but it can pull some of the crap out of blocked passages until you get a chance to go through it.
MCLMM
UZI4U is offline
post #10 of 37 Old 04-06-2013, 04:43 PM
g33kdrummer
Enjoy it man.. that's kinda the whole fun about having a Jeep.. you learn, you play, you break it, you fix it , you play some more!
g33kdrummer is offline
post #11 of 37 Old 04-06-2013, 05:41 PM
SLCSmoker
You forgot - "You spend lots and lots of $$ on it".
post #12 of 37 Old 04-06-2013, 05:50 PM
bigsquat
ditto on this.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #13 of 37 Old 04-07-2013, 01:04 AM Thread Starter
JeepingJustin
Yup its a jeep thing!
Ive checked timing an compression, cause I thought that might be the issue but both of those checked out good. I'm thinking Ive got a vacuum leak on those spacers for the weber setup. An I've tried tightening the studs an added lock washers but it still hasn't helped at all. Must be warped or cracked?? So I'm going to do a motorcraft/holley carb swap. Found some on ebay super cheap that need rebuilt. But I'll check the local scrap yards first so I dont have to pay shipping an I can see it before I buy it.
So I need a 2100 or 2150. With 1.08. there seems to be alot more 1.21 an even 1.14. Will the 1.21 an 1.14 work without flooding it?
Thanks for your input guys an I'll let ya know how it comes togather.
post #14 of 37 Old 04-07-2013, 05:25 PM
Renegad87
1987 YJ Wrangler
I have the Weber on mine and it is a pain in the A$$ to tune. What model Weber is it? If you plan on trying to tune it again I can give you some advise. If your going the motorcraft route let us know how it goes.
Renegad87 is offline
post #15 of 37 Old 04-07-2013, 06:43 PM
jmet87yj
1987 YJ Wrangler
Sorry didn't see this thread earlier..an i need help..i ha
ve 87 yj 2.5 that loads up an spits an spudder an dies while idling can someone tell me what cause this an how to fix it..thanks..
jmet87yj is offline
