Off With The Body Lift! - JeepForum.com
post #1 of 6 Old 08-16-2011, 10:35 PM Thread Starter
kjg26
kjg26's Avatar
Ok I am about to remove this goofy 3" body lift put on by the PO. I have been soaking all the bolts in PB blaster and about ready to begin the removal. I have not done a body lift on a YJ, but have on a TJ. As I recall the TJ lift had an extended piece in the steering shaft as well as brackets for the radiator and T-case. I know I have drop brackets on the radiator shroud, but unsure of the PS extension or the T-case bracket. Anything else I need to look out for when lowering her back down. Going from a 3" mess to a small one inch body lift/body mount replacement by Daystar.
Thanks
Keith
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 6 Old 08-16-2011, 11:00 PM
19OlllllllO41
19OlllllllO41's Avatar
Thanks
Keith
Nice to hear your removing that mess! Sounds like your on the right track to bringing her back down to earth..... One other thing to check is the fuel filler hose. On 3in BL's the filler hoses are often extended, so you may need to shorten the hose a bit if they lengthened it.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #3 of 6 Old 08-16-2011, 11:06 PM Thread Starter
kjg26
kjg26's Avatar
10-4. Now just to figure out what to do about the suspension. I'm looking around for lifts, found a RE 4in kit in the 800s. and a Fabtech 3.5 in kit in the 700s. I'll be using some boomerangs as well with 5/8 in lift. I'm leaning towards the Fabtech lift. unless steered elsewhere.
kjg26 is offline
post #4 of 6 Old 08-16-2011, 11:19 PM
timatoe
timatoe's Avatar
Also check for any non stock wiring that may have been ran under the tub etc...
timatoe is offline
post #5 of 6 Old 08-16-2011, 11:32 PM
zte87
GIVE IT THE ONION
zte87's Avatar
I am running the fabtech 3.5 springs and love them
zte87 is online now
post #6 of 6 Old 08-16-2011, 11:35 PM Thread Starter
kjg26
kjg26's Avatar
All non.stock wiring has been removed. She in no longer an imminent fire hazard.
kjg26 is offline
Cutting body lift spacers ? How long are 1 inch body lift bolts ? MAYNARDZ71 TJ Wrangler Technical Forum 13 11-12-2012 11:33 AM
Body mounts spinning 3 icnh body lift plmqazed YJ Wrangler Technical Forum 3 07-22-2011 10:57 PM
Rough country body lift vs zone body lift BadKarma1701 TJ Wrangler Technical Forum 5 01-24-2011 09:53 PM
JK Body Lift? Rock Sliders Move WITH BODY? trowand JK Wrangler Technical Forum 17 01-04-2009 03:34 PM
to body lift or not to body lift? atlas trouble twistedtj TJ Wrangler Technical Forum 9 08-21-2003 12:35 AM
