OE leaf spring ? - JeepForum.com
post #1 of 4 Old 12-30-2011, 06:06 PM Thread Starter
40dog
OE leaf spring ?
i'm pricing stock yj spring packs .I have used the search function and now i'm asking for distributor suggestions to order from. before you ask why stock leafs . Doing a mild spring over "soa" i don't want a skyscraper in the end so staying stock with the leafs.
40dog is offline
post #2 of 4 Old 12-30-2011, 06:17 PM
JrTjK
1978 FSJ Wagoneer
Google search 52003448 + 52003449. Those are hd stock replacements and I've seen a few of these installed with good reviews.
JrTjK is offline
post #3 of 4 Old 12-31-2011, 12:40 AM
'92 vegas YJ
I bought some used ones off craigslist when I did mine. They started to flatten real quick so I made a bastard pack out of them and some pro comp springs I had.
Not too bad so far...
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is online now
post #4 of 4 Old 12-31-2011, 06:44 AM Thread Starter
40dog
my stock fronts are bent bad.the jeep had been in a accident of some sort or the po may have jumped it which caused the front springs to bend after they bottomed out and the axle smashed the oil pan . .I can probably bastard the rear packs they look good still. I think i will leave the new u bolts long and see if the packs work when they are re built . thanks folks. You should see the 3-4" hole in the block where it riped the engine mount off along with some block casting. the end of that 4.2
40dog is offline
Leaf spring help! Yjmudding YJ Wrangler Technical Forum 9 07-06-2011 01:47 AM
Leaf spring or coil spring??? qewbawl YJ Wrangler Technical Forum 16 05-15-2011 05:28 PM
Leaf Spring Help! hammy223228 YJ Wrangler Technical Forum 5 12-01-2010 05:28 PM
Hanging the rear spring shackle from another leaf spring, NOT the frame. ideas? Big-n-Broke-YJ YJ Wrangler Technical Forum 42 09-03-2007 08:32 PM
How much arc should a leaf spring have ? JohnW YJ Wrangler Technical Forum 6 11-08-2005 02:39 PM
