odometer rolling backwards? - JeepForum.com
post #1 of 15 Old 08-04-2014, 06:58 AM Thread Starter
steveosmith
Plain and simple my odometer and the little trip meter just started rolling backwards lol ... Any reason why ???
steveosmith is offline
post #2 of 15 Old 08-04-2014, 07:21 AM
crackedcornish
is your Jeep somehow related to Christine??
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 15 Old 08-04-2014, 07:36 AM
Jeepsr4me
Can not think of a mechanical way for it to do it. So its haunted. I would drive it like it is till it gets almost back to 000001..... Cause you dont know what will happen after that...
Jeepsr4me is offline
post #4 of 15 Old 08-04-2014, 08:08 AM
jaycal3
Video of said odometer rolling backwards???
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #5 of 15 Old 08-04-2014, 08:52 AM
YJTim89
Did you drive home backwards so Cameron's father wouldn't know you took his Ferrari? Oh wait wrong vehicle...
YJTim89 is offline
post #6 of 15 Old 08-04-2014, 09:16 AM
Old4X
1990 CJ7
It is electronic, not 100% mechanical. Failed internal circuit.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 15 Old 08-04-2014, 09:39 AM
Jeepsr4me
Its cable that goes to the dash, after that I dont know what it drives ..
post #8 of 15 Old 08-04-2014, 01:12 PM
roadyrob
1987 YJ Wrangler
no, its a 95, no cable, electronic.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #9 of 15 Old 08-04-2014, 01:14 PM
Jeff88
I never get these type of problems. Mine would probably roll forward at 3x the speed.
Jeff88 is online now
post #10 of 15 Old 08-04-2014, 01:17 PM
PROJECT 23
You mounted your tires backwards. Duh!!!
PROJECT 23 is offline
post #11 of 15 Old 08-04-2014, 09:16 PM
Gungnir
Check your flux capacitor
the check engine light and coolant sensor bad warning on my ZJ arnt on. I think my jeep might be broken :(
Gungnir is offline
post #12 of 15 Old 08-05-2014, 06:41 AM Thread Starter
steveosmith
Maybe I should let it go back to 1 and sell it as a new left over from 95 lol
post #13 of 15 Old 08-05-2014, 08:07 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Serious answer... assuming this is a thread about an actual problem vs trolling, the system is electronic. The only thing the bottom end does is make pulses. The speedo gauge in the dash interprets the pulses and decides how to move the needle and odo number wheels, so the actual gauge is the likely problem point.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #14 of 15 Old 08-05-2014, 11:30 AM
Que89YJ
x100 with Don. It must be the gauge itself. Youtube it!
Que89YJ is online now
post #15 of 15 Old 08-05-2014, 01:01 PM Thread Starter
steveosmith
Maybe I'll try to find a wrecked one and switch out the cluster , mine probably is messed up for some reason I have water that leaks from somewhere behind the dash and drops out on my legs when it rain s hard
