Odd circuit board in black case next to battery. What does it do? - JeepForum.com
post #1 of 19 Old 09-04-2008, 06:46 AM Thread Starter
spshultz
1987 YJ Wrangler
This has been bugging me because I can't find any info on it in my Haynes manual but what in the world does that long PCB (printed circuit board) in the black plastic case next to the battery, relays and passenger side fender do? It's stuffed back in the corner under the test point connections and the relays on the passenger side next to the firewall. It was just dangling there and flopping around smacking the firewall. Is it for the intermittent wipers or maybe the A/C or ignition?
Thanks!
Shawn
spshultz is offline
post #2 of 19 Old 09-04-2008, 06:55 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
By all means, post a pic of that. I have never heard of such a creature in the pre FI YJ's.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 19 Old 09-04-2008, 07:04 AM
NEVER-ENOUGH
Aftermarket alarm???? I'd like to see it too.
NEVER-ENOUGH is offline
post #4 of 19 Old 09-04-2008, 08:06 AM
Felonious_monk
It is the diode/fuse assembly......I have no idea what it does either....but that is what it is.
I have an 88 4.2L it is shown on the wiring diagram on page 6-26 of my chilton manual.
Felonious_monk is offline
post #5 of 19 Old 09-04-2008, 08:12 AM
rustywrangler
It also calls for one on my 89...... Not there. Do you have a picture of it???
post #6 of 19 Old 09-04-2008, 09:10 AM
fyrdriver
1983 CJ7
Does it connect to the throttle linkage? Mines a 95 and thats were the cruise control is mounted.
fyrdriver is offline
post #7 of 19 Old 09-04-2008, 09:21 AM Thread Starter
spshultz
1987 YJ Wrangler
Unfortunately my wife has the camera so I can't take a pic now. I'll have to do that later tonight.
But yeah, there's definitely a diode on it.
The wires disappear into the loom and I really don't want to crack that loom open to trace them.
What is section 6-26 called in the Chilton's? Maybe I can cross reference that in my Haynes. Is it part of the charging circuit or cruise or lights or etc?
spshultz is offline
post #8 of 19 Old 09-04-2008, 05:38 PM
Felonious_monk
It black right? With a circuit board inside of it.....there are about 5-6 wires running into it with nothing coming back out
Its in the electrical diagrams section. Under 1988 4.2L engine wiring.
I only know what it is becuase I stubled upon it when rewiring the engine bay. I still dont know what it does. I did cut the wires that I didnt need that were running to it. I left one or two still connected though.....one was for the rear defroster, and I can't remember what the other is for.
Good Luck
post #9 of 19 Old 09-05-2008, 08:25 AM Thread Starter
spshultz
1987 YJ Wrangler
OK. I hope I can get these pics to display correctly.
Here's an outside shot of the little black case/box and then a somewhat blurry inside pic.
Like Felonious said, there are about 5 or 6 wires coming out of it.
I definitely see orange, black, pink? and purple? or violet? and one other color.
spshultz is offline
post #10 of 19 Old 09-05-2008, 08:53 AM
rustywrangler
I did some digging around and found that box tied up back near the brake booster. When I undid the zip tie, it reaches all the way over to where your pic shows.
I did a quick test and that box is in fact what I said it wasn't earlier. It has the controller for the rear defroster etc.
post #11 of 19 Old 03-26-2009, 11:54 AM
Mr-Rock
Hi, I'm new to the Forum so I hope this is where I should ask this question.
What are the two relays for next to this black thing?
Mr-Rock is offline
post #12 of 19 Old 03-26-2009, 12:08 PM
Burnerman
Burnerman's Avatar
One is for the electric choke. I can't remember what the other is for. I was gonna ask the question about the black diode box, now I know. I just left that stuff alone. The 2 plugs on the top are diagnostic's on the pulse air system.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #13 of 19 Old 03-26-2009, 12:18 PM
buckshot500
I think there is some crap in there for the sol-vac idle kicker chumpy too.
I accidentally chopped mine out with the emissions wiring.
The one towards the rear is for the electric choke, & the forward one is for the intake manifold heater.
I went to a cable for the choke when I did the MC2100 swap.
My heep's P/O had connected the blue choke wire from the choke , to the intake heater (red wire). It's supposed to have the Pink wire connected to the red wire.
The intake heater is good to have, & should be left alone.
buckshot500 is offline
post #14 of 19 Old 03-26-2009, 12:19 PM
timatoe
timatoe's Avatar
Choke and manifold heater.
Edit: I see Buckshot beat me to it.
timatoe is offline
post #15 of 19 Old 03-26-2009, 12:33 PM
Mr-Rock
Thanks, I'm putting in a dual battery tray and need to relocate these. I guess I can mount them under the new tray as i should not need to get to them often.
Mr-Rock is offline
Printed circuit board repair? TheNewbie YJ Wrangler Technical Forum 14 05-01-2014 11:09 AM
YJ Gauges gone goofy - bad ground or bad circuit board? squibload YJ Wrangler Technical Forum 18 08-06-2008 08:46 PM
Gauge Cluster Circuit Board Al-88Wrangler YJ Wrangler Technical Forum 8 10-26-2007 03:51 PM
Circuit Board for a YJ. stepbill YJ Wrangler Technical Forum 6 12-04-2005 01:36 PM
Where to buy printed circuit board behind gauge cluster? pyro9862 YJ Wrangler Technical Forum 8 02-14-2005 09:21 PM
