odd bellhousing sounds - Page 2 - JeepForum.com
post #16 of 17 Old 10-07-2012, 02:35 AM Thread Starter
riverhippy
Originally Posted by pete1991YJ View Post
You got the internal slave bearing right? With the 6-cylinder?
On an external slave it would just have a bunch of slop in its motion, enough to screw with the shifting prolly. On an internal one I dunno what you mean by the retaining nut, can you post a pic? When I changed mine the other month, there wasn't any nut, just a small pin.
peetay! wazz mah man doin??? ill post a shot but its the same as you describe for both...theres a pin and a push nut goes on top top to hold throwout bearing in place.
let me know if this can be the cause of the odd sound...banging...i can hear in all gears. although its moot, i'd like to know. ill post the pics of my trans rebuild as i go.
riverhippy is offline
post #17 of 17 Old 10-07-2012, 09:14 AM
pete1991YJ
Yeah if that pin or the push nut is gone then you will get all kinds of noise and one effed up bearing. Hint the pin doesn't *have* to be a pin, you could run a self-tapping sheet metal screw into the hole instead. I did that on my old XJ cherokee yrs ago. Basically zip-screw the bearing into the housing thru that little tab it has for that pin.
You can fix this for a 19 cents!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
bigboobslittlelegs , boobs , hugeload , tranfer case , tranny problem
Bellhousing jleal_21 YJ Wrangler Technical Forum 1 09-15-2010 06:19 AM
BellHousing ColoradoCole TJ Wrangler Technical Forum 2 08-01-2010 10:20 PM
Bellhousing? cjwdzr YJ Wrangler Technical Forum 2 02-25-2010 10:01 AM
AX-5 / BA-10 bellhousing? Cadetvette87 YJ Wrangler Technical Forum 3 01-19-2010 01:17 PM
Need a little bellhousing help please... 1987jeepyj YJ Wrangler Technical Forum 5 01-23-2009 11:18 AM
