Need some help, please.
The check engine light came on two days ago. The voltage gauge indicated a low output, so I assumed the alternator was going bad. When I popped the hood, though, the alt seemed to be operating as normal. I knew the battery was getting on in years, and when I had the oil changed at a service center this past winter they said the battery would need to be replaced soon, so naturally I went out and spent the money for a new battery. However, the check engine light still was on, and voltage still registered a low output. When all guesses fail, I decided it was time to check the OBD code, which I guess I should have done in the first place.
I got one code, a 34. The problem is, I have no idea what it means:
An open or shorted condition detected in the Speed Control vacuum or vent solenoid circuits. Speed control switch input below the minimum acceptable voltage
I can change the oil, and some other basic stuff, but other than that, I'm not much of home mechanic. So I have no idea where to start on this. Any help would be appreciated.
94 Jeep Wrangler YJ
4.0L 6 cylinder
Thanks in advance.
94 Jeep Wrangler YJ
4.0L 6 cylinder
Thanks in advance.
