Quantcast oba.. what size tank and where did ya mount it? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > oba.. what size tank and where did ya mount it?
Ruffstuff Axle Simple Swap Kit!Truck-Lite's New LED Headlamp SeriesSpartan Lockers FREE SHIPPING Excellent Prices
Old 01-28-2006, 06:14 PM   #1
cueball
it seems as if the 2.5gal or the 1.75 gallon are the ones out there .. i was thinking about mounting it in front of the gas tank ..but i am not sure if i have enough room for the 2.5gallon..
does anyone have pics? i am planning to buy on monday and need to know.
thanks
Bye to the old - 1988 6 cyl 5 speed with a 94 rollbar, tomken 2x4 rocker skids and homebrewed OBA.
Hello to the New - 1999 TJ Sport 4.0L auto.. stock for now
cueball is offline   Reply With Quote
Old 01-28-2006, 07:01 PM   #2
Flashfoto
Before you put it ahead of the gas tank, make sure your diff. housing won't come up & smash it. That was my first thought, too. But, I ended up making special bracket's and hanging it between the frame & tranny.
Flashfoto is offline   Reply With Quote
Old 01-28-2006, 07:32 PM   #3
jeffy
I have my 6x6x18" hotdog mounted in front of the gas tank. You'll really want to make sure you have room though. Unless you're jumping your Jeep the rear diff shouldn't move upwards that much. I was thinking about mounting it parallel to the driveshaft but the floor is uneven and the tank would be slightly lower then the frame rail. A 1" body lift would ahve solved this though.
Honestly, if I was going to do it again, I'd get two smaller tanks, 1.25 & 1.75 gallon, and run one parallel to the rear driveshaft and one offset in front of the diff.
www.4BangerJP.com
A Pitiful RigRater Score: 789RRv1.0
jeffy is offline   Reply With Quote
Old 01-28-2006, 09:30 PM   #4
Flashfoto
I agree with Jeffy on doing two tank's. Especially if you haven't bought one, yet. Next time, I think I will look into some old fire extinguisher or welding tank's that might be longer, but smaller in diameter. Or, make my own out of pipe. Heck, even PVC will hold up at 125psi . My shop has had about 200' of PVC airlines in it for 24 year's with no problem's.
Old 01-30-2006, 10:59 AM   #5
superjoe
i ahve a 4gallon tank mounted on the passanger side fender next to the back seat.
Joe Clark † 210-639-0276
/l ,[____], 82 CJ 8 Scrambler Currently all stock but that will change.
l---L--0lllllll0- Christian 4x4.com
()_) ()_)----)_)
superjoe is offline   Reply With Quote
Old 01-30-2006, 12:31 PM   #6
E_ROCK
Here is my write up.
http://www.rockfrogs.org/phpBB2/viewtopic.php?t=2
Picture of tank
It is mounted on driveside between frame and driveshaft.
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is offline   Reply With Quote
Old 01-30-2006, 12:57 PM   #7
superjoe
eelson, nice write up.
i used a York Compressor and made the mounting adapter myself and mounted it in the stock AC location. i have 2 out puts as well 1 under the hood, and one off the back of the tank in the back on the Jeep.
()_) ()_)----)_)
Old 01-30-2006, 03:16 PM   #8
mjeselskis
I used two fire extinguishers that I got for free. In the pic it looks like the tanks hang down below the frame rails but it doesnt hang down at all. I used some 1" wide steel stock to wrap the tanks and mounted them to the bottom of the tub. It works pretty well. I just need to order the components to control the compressor now.
1989 black YJ, 2.5L 5speed
SOA on stock springs with add a leaf in rear, Welded D30, Posi-Locked, traction bar, Rear 5/8" Boomerang Shackles, OBA, Ditched Front and Rear Trac Bar, 34x10.5 LTB TSL Swampers on 15x8 M/T Classics, Ramsey Pro Plus 9000
mjeselskis is offline   Reply With Quote
Old 01-30-2006, 03:30 PM   #9
Redskinswin
OBA? Please explain? Sorry but fairly new here.
89 YJ, 2.5 L 4 INCH RC LIFT, 32X11.50 BFG AT, Bestop Tire carrier, Hi-Jack, Champion 8000lb Winch ($300 bones at Costco), Bestop Trailmax Seats, KC highlights on the windshield, Classic Rock Krawler Bumpers front and rear.
Redskinswin is offline   Reply With Quote
Old 01-30-2006, 03:32 PM   #10
superjoe
OBA = On Board Air
in otherwords compressed air used for airing up tires or to run air tools
()_) ()_)----)_)
Old 01-30-2006, 04:23 PM   #11
Redskinswin
That is a great idea.......Will have to look into that upgrade. Love this site!
Old 01-30-2006, 04:28 PM   #12
superjoe
this pic was taken for my my TJ flares but you can see the tank there.
()_) ()_)----)_)
Old 01-30-2006, 04:35 PM   #13
superjoe
here is my OBA set up, i didnot realize i had these pics on the work puter, they are about a year old but ithas not changed much
()_) ()_)----)_)
Glock Forum
