OBA system - JeepForum.com
post #1 of 9 Old 02-21-2007, 06:00 PM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
OBA system
i am looking into buying / building an OBA system.....
i will be going down the the OBX, NC for some beach wheeling and i am going to need to air down....
I've seen the 12 volt air compressors at tractor supply, cheap little 30.oo thing, but i am assuming (pretty damn sure) that they are slower then hell....
What i am thinking is i have a 5 gallon portable air tank that i could use as a holding tank, but prolly wouldn't be enough to inflate 10 psi in all 4 tires.... so i'd need to replenish the air in the tank with something....
what can i use...
i have 100.00 for the system....
i am an avid paintballer and i have 3- 20 oz co2 tanks, and a 92 CI, 4500 PSI air tank i can use.... however i have no tire fittings...
we have a regular compressor that runs 110v and holds 15 gallons, but that wont fit and or run in the jeep.....
ideas??
03Wrangler is offline
post #2 of 9 Old 02-21-2007, 09:55 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Check out this thread. It's in the General Offroad section, which I think this thread should probably be. I have the red MV-1050. It's great.
http://www.jeepforum.com/forum/f27/harbor-freight-vs-costco-portable-12v-air-compressor-depth-review-w-pictures-378082/
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #3 of 9 Old 02-22-2007, 07:09 AM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
so no holding tank is necessary.....
i had seen this thread after making mine.... thing is there are no costco's around here...
post #4 of 9 Old 02-22-2007, 07:54 AM
jeepster93
jeepster93's Avatar
2 words...
Harbor frieght.
They sell a small portable that will work if you are not in a hurry, and it's less than $50.
ME...I felt airing down is SO important that I did a belt driven oba.
jeepster93 is offline
post #5 of 9 Old 02-22-2007, 03:08 PM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
what CFM is good for 31" tires....
I don't want to spend 15 minutes Airing back up, however i don't need anything that loads them up in 10 seconds....
harbor freight sounds like it is a slower and hotter pump then the costco.... i am looking for costco quality... online or wherever..
thanks
post #6 of 9 Old 02-22-2007, 03:25 PM
mylt1
mylt1's Avatar
i have a SCBA bottle setup with a modded wielding reg on it to control flow. i can air up in no time. it holds 60ft^3 at 2500PSI. only thing is i can fill it at my fire house you would have a problem with that but any dive shop will fill it for a fee.
mylt1 is offline
post #7 of 9 Old 02-22-2007, 03:36 PM
mylt1
mylt1's Avatar
northern tools has a 12v 300 psi truck and suv pump of $44.99 in there catalog. item # 2000420-2606x
mylt1 is offline
post #8 of 9 Old 02-22-2007, 06:03 PM Thread Starter
03Wrangler
03Wrangler's Avatar
2010
i found a site that compared all the compressors( well allot)
nothing seems to be incredibly fast besides a Co2 tank... So i will just buy a HF one and have a few sodas while i wait
might even permanently mount it.. see how it works.
post #9 of 9 Old 02-23-2007, 12:12 AM
Mr.B
Mr.B's Avatar
I got mine from Pep Boys. $50 after the $10 rebate(which I haven't gotten back). It's an MF-1050. Their web site seems to be down right now so I can't give you a link. It's www.pepboys.com
Ham license:
Everyone is Welcome
Mr.B is offline
vacuum system hoses all hooked up but system doesnt work snowcrawlr619 YJ Wrangler Technical Forum 8 12-28-2009 07:52 AM
Getting Rid of A/C System tgrout YJ Wrangler Technical Forum 6 03-11-2009 12:59 PM
In a rut with my HID system wvangel87 TJ Wrangler Technical Forum 4 06-30-2008 05:02 AM
PCV system cmcgover YJ Wrangler Technical Forum 9 01-09-2008 07:59 AM
PA system AK1904 YJ Wrangler Technical Forum 1 12-29-2003 04:06 PM
