OBA Pressure Switch - JeepForum.com
post #1 of 12 Old 12-06-2009, 01:20 PM Thread Starter
Jesse_87
OBA Pressure Switch
Does anyone know of store that carries this type of pressure switch? Advance Auto, Napa, AutoZone, O'Rileys etc. It's the only thing holding up progress on my OBA system.
Jesse_87 is offline
post #2 of 12 Old 12-06-2009, 01:36 PM
timatoe
timatoe's Avatar
I couldn't find anyone local to me that carried one. I bought mine from these guys... AirBagIt.com - Air Suspension Kits, Mini-Truck Parts, Sport Compact Parts! Airride, Airsprings, Towing Kits, Lambo Vertical Doors, Airbags. It was the best price I could find.
Pretty sure mine was the 110 on /135 off
timatoe is offline
post #3 of 12 Old 12-06-2009, 02:20 PM Thread Starter
Jesse_87
Thanks. i was trying to keep from ordering one, I'm weird like that. But that's the cheapest I've seen so far, so I may just go that route. Thanks again man.
Jesse_87 is offline
post #4 of 12 Old 12-06-2009, 02:55 PM
plumber1
Try Grainger Supply, or some other type of contracors supply
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #5 of 12 Old 12-06-2009, 05:25 PM
dodger889
A regular air compressor supply shop should have what you are looking for. The contacts could be rated for 110 ac but will work for a dc just make sure of amperage rating. If I'm not mistaking you should be looking for about 10 amps for the clutch.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 12 Old 12-06-2009, 05:45 PM
kasbiker38
i just bought a cambel husafeld compressor from wall mart cheep that had the switch and a 2 gallon tank and a manifold for all my do dads for like 70 $ i thought it was a good way out.
kasbiker38 is offline
post #7 of 12 Old 12-06-2009, 05:49 PM
Oscar_P
kasbiker, can you find a link? I'm interested
Oscar_P is offline
post #8 of 12 Old 12-06-2009, 05:49 PM
TSEJEEPERS
I am using one like this.
Switch Pressure Single Stage - 3433901 | Tractor Supply Company
Works fine. You can find the ones from square D all over the place.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 12 Old 12-06-2009, 07:07 PM Thread Starter
Jesse_87
I have one like that, but i don't know which of the outlets to use. It has 4 or 5. It came off a used compressor that was taken apart when I got it. I have looked up the part number and all i could find was replacement ones not plumbing diagrams for it.
Jesse_87 is offline
post #10 of 12 Old 12-06-2009, 07:46 PM
kasbiker38
Product - 2 Gallon Air Compressor - from Campbell Hausfeld
that is a newer model but the same thing i think. mine looked judt like that but cheeper. Had the little preasure switch and every thing!!!
post #11 of 12 Old 12-06-2009, 07:53 PM
Oscar_P
I like that Kasbiker. thanks for the link. did you hardwire it into your Jeep? if so how?
Oscar_P is offline
post #12 of 12 Old 12-06-2009, 08:38 PM
kasbiker38
it is a 110v compressor so i had to take it all apart and do the regular oba set up with the ac pump but it has all the required gismos in one packidge so all you would need to buy is an oiler a toggle switch some wire and some air hose. it worked out sweet for me.
A/C low pressure cut-off switch CheapSunglasses YJ Wrangler Technical Forum 4 07-31-2009 08:17 AM
Pressure Switch? Projekt89 YJ Wrangler Technical Forum 1 04-28-2009 03:28 PM
Air pressure switch ? Gonewhln YJ Wrangler Technical Forum 8 12-26-2008 05:34 PM
Oil pressure switch madmikey TJ Wrangler Technical Forum 3 05-22-2008 03:12 PM
12V Pressure Switch for ARB? MRoth YJ Wrangler Technical Forum 0 08-27-2005 11:03 AM
