OBA option? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > OBA option?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 10-05-2005, 09:39 PM   #1
mjeselskis
OBA option?
I just got thinking during my mechanical design class today while I was bored. Could a turbo be used for OBA for the compressor? I havent done much research but I would think some turbos, especially diesels would be able to put out like 80 psi. So could you just bolt a turbo in, run oil lines and use that to fill a tank, etc. I cant seem to think of why it wouldnt work unless a turbo just wont put out enough pressure. But assuming its just a small turbo with a regulator setting it to like 80 psi, it seems like it is plausible. Let me know what you guys think.
1989 black YJ, 2.5L 5speed
SOA on stock springs with add a leaf in rear, Welded D30, Posi-Locked, traction bar, Rear 5/8" Boomerang Shackles, OBA, Ditched Front and Rear Trac Bar, 34x10.5 LTB TSL Swampers on 15x8 M/T Classics, Ramsey Pro Plus 9000
mjeselskis is offline   Reply With Quote
Unread 10-06-2005, 09:21 AM   #2
E_ROCK
Seems to me like turbos are move expensive than getting a stock sanden out of a bone yard. A stock A/C can get a lot higher psi.
Buy, hey I would love to see someone do anything new.
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is online now   Reply With Quote
Unread 10-06-2005, 10:52 AM   #3
mjeselskis
Yeah I was just thinking I could get a cheap used turbo but I think you are right about the A/C. I just cant find a bracket and was gettting frustrated. I was just looking for another option. But upon further research I would have to have alot of heat and exhaust gas to get enough pressure to make it work. Probably not realistic but I was just thinking.
Unread 10-06-2005, 11:05 AM   #4
E_ROCK
I know nothing about the 2.5L engine. I know the 4.0 already have the A/C braket weither you have A/C or not. Keep looking around, I sure you come across a bracket.
If I had to make mine own bracket, I would make it fit a york rather than a sanden.
www.rockfrogs.org
Unread 10-06-2005, 11:17 AM   #5
Slapahoe
Registered Jerk
Slapahoe's Avatar
As a old Turbocharged car fan, I can tell you that unless you are dealing with a very very strong Semi Engine, it will be impossible to ask that amount of pressure out of a turbo ande your engine take it.
Lets put it this way. I had a built VW Golf before I bought my Vehicross. It was running at about 20PSI from its stock 9.5PSI setting. 20PSI an incredible amount of pressure. 80 is just rediculous!
Also, If you threw a turbo up there just like you said, your talking about air that would be SO HOT at even 20 PSI you could melt a tire if it was directly put into the tire without filtering through atleast a air/water intercooler.
93 YJ 4.0HO
'03 KJ Renegade
Slapahoe is offline   Reply With Quote
Unread 10-06-2005, 03:47 PM   #6
schitzangiggles
King of Mac-istan
schitzangiggles's Avatar
Try these guys for your OBA needs, kinda pricey but it is 100% gonna work and he stands behind his stuff. http://www.kilbyenterprises.com/
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is online now   Reply With Quote
Unread 10-06-2005, 09:12 PM   #7
mjeselskis
he has nothing for my 89, i already emailed him and asked
Unread 10-07-2005, 08:29 PM   #8
schitzangiggles
King of Mac-istan
Let me check my files and see what I can find for you.
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
