O2 sensor should or should not be connected to ?? - Page 2 - JeepForum.com
post #16 of 21 Old 03-27-2013, 08:38 AM Thread Starter
YJ-dimi
QUOTE=Que89YJ;15201564]YJ-dimi did you do a battery reset? The PCM stores info and you need to clear it. Also after running rich that long you might want to clean out the IAC. I bet its carboned up pretty good.[/QUOTE]
Hey, yea the battery is always disconnected while it sit through winter. I thought an 8 hour battery disconnect is good enough to clear the memory without any tricks. i think one week will defenitely clear out the memory.
I'll take it out next time i change oils, as i don't have idling issues at the moment. but a good tip is always welcome.
YJ-dimi is offline
post #17 of 21 Old 06-27-2013, 05:10 AM Thread Starter
YJ-dimi
after some driving i have considerable improvement of fuel economy. last fill-up i got an average of 13.3L/100km which is around 17.6MPG compared to 14.1MPG without the O2 sensor. . thanks for the help.
YJ-dimi is offline
post #18 of 21 Old 06-27-2013, 10:42 AM
bchap05
I changed my o2 a week or so ago. I had the tire shop pop it loose for free while rotating my tires so it was easy change took 5 minutes. I was going to reset the computer but never ended up doing it. Jeep runs smoother and better than it ever has since I've had it. Will the computer by now have retrained itself or should I still reset at this point still?
bchap05 is offline
post #19 of 21 Old 06-27-2013, 11:54 AM
idaholtby
It likely relearned by now and is acting upon the new values. An ECU reset will help with the first three full drive cycles. I bet by now it is no longer worth doing.
idaholtby is offline
post #20 of 21 Old 06-27-2013, 08:54 PM
pete1991YJ
You should always reset the computer after changing a sensor. They weren't that smart back then, compared to the newer ones. It only takes a minute to disconnect the battery for a few seconds.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #21 of 21 Old 06-28-2013, 07:38 AM Thread Starter
YJ-dimi
i don't know if these era jeep ecu re-train themself but it doesn't hurt the ecu for sure. mine spends more time off-juice then on during the year and in the meantime between trips i always disconnect the negative lead with a quick disconnect. very efficient way to preserve your battery over time and it prevents empty battery. i've read at least an 8 hour disconnect would clear the memory.
YJ-dimi is offline
