O2 sensor should or should not be connected to ?? - JeepForum.com
post #1 of 21 Old 01-31-2013, 07:33 AM Thread Starter
YJ-dimi
Hi,
can anybody help me with solving next question:My engine should or sholdn't have an O2 sensor fitted?
My wrangler has a 1994 4.0HO engine which was ran on leaded gas in the past. today it's converted to unleaded gas by cilinderhead change. The O2 sensor hasn't been present since i bought it. It runs rich (by smell and gasmileage ). The PCM doesn't send any error code on behalf of the O2 sensor so i really can't say if connecting an O2 sensor would make the PCM work with it. the O2 connector is present nearby the exhaust manifold plug but has a seal pressed in the wire-leads. I'm looking into a LPG sequantiel injection conversion kit but for avoiding lean-mixtures with gas i'd preffer a PCM working with the O2 sensor that adjusts the fuelmixture.
YJ-dimi is offline
post #2 of 21 Old 01-31-2013, 08:02 AM
Que89YJ
Put one in. Yes it came stock with an O2 sensor. Yes it will run rich. OBD I diagnostics dont always come on when it has codes but this is how to check:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
post #3 of 21 Old 01-31-2013, 08:05 AM
pete1991YJ
Yes all YJ models have an O2 sensor. It will run very rich without it, giving poor gas mileage and poor performance. Leaks at the manifld will cause the same troubles. The computer should have stored a fault code without the sensor. Also, the computer does not read the sensors until the engine temperature is above 185 deg fahrenheit. It runs in "open loop" mode until then. Hope this helps!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #4 of 21 Old 01-31-2013, 08:34 AM Thread Starter
YJ-dimi
i check codes every year when changing oil(5 in total) never had a O2 sensor related code. the only code I recall is the 55code (end of code output) that's why i'm comfused about the O2 sensor. Never measured for voltage on the wiring though maybe i'll start with that. i geuss no use for O2 sensor no use for voltage on the connector.
YJ-dimi is offline
post #5 of 21 Old 01-31-2013, 08:40 AM Thread Starter
YJ-dimi
gives nice explosions in the exhaust when going of gas and back on but but is there's no faultcode stored because of the missing O2 sensor last 5 years. when i find voltage on te connector i'll put one in and see what happens. is there any way to check if the PCM works with the O2 sensor when it's plugged in?
YJ-dimi is offline
post #6 of 21 Old 01-31-2013, 09:33 AM
Que89YJ
You will know the difference. If you bought the right obd I reader for the YJ you could look at the actual numbers from the ecu. I dont know what one to recommend but I am sure you could find one with a little research. The difference in your fuel economy will be apparent after you do the change. Make sure you do a battery reset to reset the ecu. You said you checked codes. You should always see 12,33, and 55. If you dont then there is something wrong. The link I posted has the methid for checking the codes.
Que89YJ is offline
post #7 of 21 Old 02-08-2013, 12:50 AM
95riorig
You should not always see 12, 33, 55
12 is only if he has disconnected the battery less than 50 engine starts.
33 is for the a/c system, if he has a/c then the code will not appear, and I believe if you don't have a/c you can unplug the a/c fuse and you won't get that code.
95riorig is offline
post #8 of 21 Old 02-08-2013, 04:29 AM
Que89YJ
You wil always see those codes on a stock controller unless you have changed out the ecu. The 33 is there because the ecu was set up for the xj with the ecu controlling the ac. Yj doesn't have it it has a stand alone ac. The 12 is a start of sequence.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #9 of 21 Old 02-08-2013, 09:09 AM
ROTTEN
My o2 code tripped on around 100. I just black taped that light until I bought a new one.
You will notice different performance with a good o2. I can't comment yet on MPG though...
I'm new
ROTTEN is offline
post #10 of 21 Old 02-08-2013, 10:37 AM
Xpress
Your engine will run worse without the O2 sensor because the computer is unable to tell what the air to fuel ratio is inside of the engine. Since it doesn't see the sensor, it runs in open loop mode, which basically means it's dumping fuel into the engine to prevent from leaning itself out to the point of destruction. You should also be experiencing poor fuel economy as well, so with the sensor in place and functioning your MPG will go up.
All about that unibody life.
Xpress is offline
post #11 of 21 Old 03-01-2013, 08:00 AM Thread Starter
YJ-dimi
since my YJ is sitting throug the winter i've started the engine today and found 12Vdc on the right lead, so i'll go ahead and order a new O2 sensor.
The voltage lead is dark green/orange, if one is to look at the wiring diagram you can get at autozone.com which show the PCM and the components connected to it, you can see that from the Vdc supply dk green/orange the 12vdc goes further as black/ light blue to other engine sensors. this is kinda ood because my O2 connecter just held a dummy plug with no connections to complete the dark green/orange lead to the black/light blue wiring to supply the other engine sensors (MAP,coolant sensor/ throttle positions e.o). I'll haveto look at where that supply is comming from now(as my engine works just fine) and maybe i'll haveto cut the connection at the O2 sensor if needed to avoid shorting out when the O2 sensor makes the connection complete between the dk green/orange & black/light blu. anybody any thoughts about this?
YJ-dimi is offline
post #12 of 21 Old 03-01-2013, 09:47 AM
pete1991YJ
If you have the 4-wire heated sensor then I wouldn't cut anything. At least one of those wires is supplying electricity to the heater inside the sensor.
post #13 of 21 Old 03-01-2013, 10:21 AM Thread Starter
YJ-dimi
Think you're right. i've looked at the wiring again comparing with a 4wire O2 plug layout and found the wire black/light blue comming from the PCM and supplying sensors with voltage so the O2 sensor plug, i think is like this
- Dark green/orange=12Vdc coming from start ignition supplying the heating element in the O2 sensor
- black is ground from the O2 heating element
- black/light blue is voltage from PCM to O2 sensor
- black/drk green is O2 sensor voltage output to PCM, for controlling air/fuel mix.
YJ-dimi is offline
post #14 of 21 Old 03-27-2013, 06:20 AM Thread Starter
YJ-dimi
final update,
Today i've installed the sensor. I ran the engine and it accepts the oxygen sensor. the engine ran smoother and after warming up there was increase in efficiency as the exhaust didn't gave as much expolosions as i went on/of gas. fuel-economy imprvement already . Thanks for the help.
YJ-dimi is offline
post #15 of 21 Old 03-27-2013, 08:11 AM
Que89YJ
YJ-dimi did you do a battery reset? The PCM stores info and you need to clear it. Also after running rich that long you might want to clean out the IAC. I bet its carboned up pretty good.
Que89YJ is offline
