O2 sensor 1992 jeep wrangler - JeepForum.com
post #1 of 19 Old 09-05-2011, 11:57 AM Thread Starter
JeepCreep454
Where is the 02 sensor on a 1992 wrangler?
JeepCreep454 is offline
post #2 of 19 Old 09-05-2011, 12:55 PM
Mark05059
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 19 Old 09-05-2011, 01:00 PM
Budke
Originally Posted by Mark05059 View Post
just after the cat on the passenger side in the exhaust pipe.
Wrong.
Its on the drivers side on the exhaust pipe. Right next to the front DS
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #4 of 19 Old 09-05-2011, 01:17 PM Thread Starter
JeepCreep454
Why would I need to change it and how difficult would it be to change?
post #5 of 19 Old 09-05-2011, 01:28 PM
Jarred2
theyre easy to change out.
She lets me ride her whenever i want. I buy her shiny things all the time. Give her a kiss and hug every morning and night. Think about her all day and dream about her at night. We have the perfect relationship. Me and my jeep that is.
The way I see it, a Jeep is like sex-when it's good it's terrific, and when it's bad it's still pretty good!
Semper Fidelis
Jarred2 is offline
post #6 of 19 Old 09-05-2011, 01:34 PM
Budke
you'd need to change it if it went bad. Could cause your jeep to run too lean or too rich.
I've been driving my jeep with no 02 sensor for a couple weeks and haven't noticed a difference in the way it runs from before the wires got ripped out of the sensor.
Budke is offline
post #7 of 19 Old 09-05-2011, 05:33 PM Thread Starter
JeepCreep454
Could it cause a low or rough idle?
post #8 of 19 Old 09-05-2011, 05:38 PM
Matt24138
Yes
_____
/l ,[____],
l---L []llllll[]-
()_) ()_)---)_)
Matt24138 is offline
post #9 of 19 Old 09-05-2011, 05:39 PM
Matt24138
If you change it get a breaker bar and do it when the exhaust is really hot.
_____
/l ,[____],
l---L []llllll[]-
()_) ()_)---)_)
post #10 of 19 Old 09-06-2011, 08:00 AM
Bad_Dog
I tried to replace mine over the weekend. After several shots of PB Blaster, each time letting it sit for 20 minutes to an hour, no luck. I let it sit for two days and tried again, still no luck.
I did run the engine for a couple of minutes - I was also changing the fuel filter so needed to ensure the new fuel lines around the filter were secure - but still no luck.
The engine didn't get above 100F, so I may have not let it run long enough to get it hot enough.
Don't have a breaker bar, but did end up buying a sensor socket wrench because my open-ended wrench started to strip it a little.
So what do you suggest... PB blast it first, then drive it around for a while, or the other way around? Never used PB on anything that was subject to heat so I don't know how well it handles 'soaking' and being 200 degrees.
OlllllO 2013 Wrangler Sahara Unlimited
[]lllll[] 1991 Wrangler Renegade, 4.0L Auto (Retired 2013)
Bad_Dog is offline
post #11 of 19 Old 09-06-2011, 08:18 AM
Que89YJ
Go to harbor freight and get a breaker bar. You arent going to get it loose without one. Especially if its been in there for a while. You can pick one up for under $20. Archemedies was right, leverage is your friend. Spray it with pb blast while cold, never hot. Let it soak overnight. Take it out and run it hard for 20 minutes to heat the exhaust then use the BB and a good socket to break it free. I have the O2 sensor socket but found it made more sense to cut back the wires on the top when I was removing it and use a 1/2" drive deep well socket.
Que89YJ is online now
post #12 of 19 Old 09-06-2011, 08:24 AM
tdewit
Now that you have the sensor socket wrench, just get a 2 foot pipe to go over the rachet. No need to go to HF and spend more money. I used a ring with a pipe.
Que89YJ is correct though, Archemedies was right, leverage is your friend.
tdewit is offline
post #13 of 19 Old 09-06-2011, 01:51 PM
Bad_Dog
I don't have a breaker bar, but what about an impact wrench? That I do have...
Bad_Dog is offline
post #14 of 19 Old 09-06-2011, 02:04 PM
Que89YJ
You can try but there is more torque with a 3 foot pipe on a breaker bar then you can get from an impact. I would try everything I had at my disposal first before buying a new tool.....but I do like shiny new tools too!
post #15 of 19 Old 09-06-2011, 03:10 PM
Budke
Mine has been in for 19 years and I took it out with just a crescent wrech. PB'd it, let it sit 15-20 minutes, let the engine idle til it got up to temp, shut 'er off and the sensor came right out.
Budke is offline
o2 sensor
1992 Jeep Wrangler no A/C Dano98 YJ Wrangler Technical Forum 5 04-13-2011 10:41 PM
1992 wrangler speed sensor mij3 YJ Wrangler Technical Forum 3 07-20-2008 04:42 PM
1992 jeep Yj wrangler Famekilla YJ Wrangler Technical Forum 2 07-18-2008 09:41 PM
1992 jeep wrangler problems Golddigger YJ Wrangler Technical Forum 18 01-18-2006 06:39 PM
FS 1992 Jeep wrangler iamthemellowman YJ Wrangler Technical Forum 3 03-22-2004 11:44 PM
