O2 Sensor? - JeepForum.com
post #1 of 10 Old 04-08-2010, 09:08 AM Thread Starter
AM0608
O2 Sensor?
My CEL comes on randomly when I'm driving and I check the codes and only 12 and 33 show up and there normal. Then today code 52 showed up so I unhooked the battery for a few mins to reset it and now 52 wont show up. My engine sputters when I'm stopped at a light other then that it runs fine. I know other stuff will throw that code other then the o2 sensor anyone know what it could be?
AM0608 is offline
post #2 of 10 Old 04-08-2010, 09:29 AM
Que89YJ
The codes dont always get set if the sensors fail in the nomal operating range but they will definitely cause you a headache. The temp sensor is a common one to fail without throwing a fault. It will cause your fuel air to be off. Also check the manifol and see if its cracked. It will cause an O2 fault. The last thing I can think off would be a vacuum leak. Check for one using the brakefluid or starter fluid.
Que89YJ is offline
post #3 of 10 Old 04-08-2010, 09:50 AM
Louie4
My jeep did the exact thing yours is doing. It would sputter coming to a stop after cruising. Well it turned out I had a clogged cat and it caused the O2 sensor code to come up.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 10 Old 04-08-2010, 10:47 AM Thread Starter
AM0608
ok sorry I'm pretty new to vehicles. How do I tell if the temp sensor is bad or if the cat is clogged? I checked the vac lines and there fine same with the manifold.
AM0608 is offline
post #5 of 10 Old 04-08-2010, 11:04 AM
Que89YJ
This should help explain it. Making Sense of Engine Sensors
Que89YJ is offline
post #6 of 10 Old 04-08-2010, 11:05 AM
Que89YJ
Que89YJ is offline
post #7 of 10 Old 04-08-2010, 03:21 PM Thread Starter
AM0608
ok so I just dorve the jeep for a bit and no CEL on now until I hit a good bump then it comes on. If I shut it off and restart it and drive it the light wont come on until I hit a bump again. I've done like 4 times and the same thing keeps happening. Anyone know what it could be now.
AM0608 is offline
post #8 of 10 Old 04-08-2010, 03:44 PM
Que89YJ
Check the wiring harness around the sensor for a short and check the manifold in the rear for crack.
Que89YJ is offline
post #9 of 10 Old 04-08-2010, 07:27 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
You may have a bad conection. You could also have a cat converter that is failing and has broken up some. every time you hit a bump a piece clogs your exhaust and that sets offf the DTC and lights up your CEL.
A clogged cat at night will even glow in the dark after a long run on the highway.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #10 of 10 Old 04-08-2010, 07:52 PM Thread Starter
AM0608
its not the cat cause I just drove it for an hour and it wasnt glowing and the light didnt come on at all.
AM0608 is offline
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 05:22 AM
Crankshaft position sensor and o2 sensor bracket help diy4x4 TJ Wrangler Technical Forum 0 03-02-2009 05:07 PM
My 2.5 takes a while to start, is it the cam sensor or crank sensor!! Divebum TJ Wrangler Technical Forum 9 12-24-2008 01:38 PM
power steering sensor needed? O2 sensor? Zorm YJ Wrangler Technical Forum 8 01-17-2008 09:06 AM
P0135; 02 Sensor Heater Malfunction, Sensor bad???? perley03 TJ Wrangler Technical Forum 5 01-18-2007 09:40 PM
