nv3550 shifter ? - JeepForum.com
post #1 of 3 Old 02-21-2007, 05:52 PM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
nv3550 shifter ?
I did a search but didn't find really anything to answer my question. I'm replacing my ax-15 sometime in the next couple of weeks, I'm just still trying to decide with what. It's either a nv3550 or a 700r. I've seen some write ups on the nv3550 and it seems pretty much like a bolt up, my question is about the shifter, if the trans is donated from a TJ, why won't the TJ shifter handle work?
Psalm 14:1
Live in Georgia? click here-->
ionakana is offline
post #2 of 3 Old 02-21-2007, 05:54 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
who said it wont?? i'd think all you'd have to do is maybe remake the metal plate under the carpet on the tunnel with the hole in the right spot for the new shifter...
thats what i did when i did the motor/tranny swap and used a b&m cable shifter....
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 3 Old 02-21-2007, 07:04 PM Thread Starter
ionakana
Grand Poobah
ionakana's Avatar
just wondering, every thread I have seen says you have to modify the yj shifter, I thought maybe they didnt line up the same. If I go that route I'll get the shifter also. Thanks
Psalm 14:1
ionakana is offline
nv3550 - loose shifter imbezol TJ Wrangler Technical Forum 16 11-22-2016 07:13 AM
Hurst shifter NV3550 jc45840 TJ Wrangler Technical Forum 7 06-20-2009 02:50 PM
column shifter to floor shifter conversion jeepwrnglr92 YJ Wrangler Technical Forum 3 07-03-2007 11:51 AM
Cherokee shifter acting as a Short throw shifter?? skyjacked94xj TJ Wrangler Technical Forum 7 02-03-2007 12:42 PM
How does the shifter attach on the NV3550? blacktjsport TJ Wrangler Technical Forum 4 06-29-2006 09:46 AM
